Passenger axle help!
Old May 28, 2008 | 02:26 PM
Evo9tunerz's Avatar
After installing my clutch I started putting everything back. Got done with the driver side axle with no problems at all and then started on the passenger's side. When I push in the axle all the way it doesn't lock up. I can pull the axle and it opens up about half an inch, but won't come out unless I pry it out. Has anyone dealt with a problem like this before? I checked the c-clip on the shaft of the t-case and it looks fine in my opinion. Can the shaft be in too far in the t-case? Any ideas would greatly help, thanks.
Here is a pic with it all the way in.
Here is a pic of it when I pull on it. It stops there and won't come out unless I pry it out.
Old May 29, 2008 | 12:00 AM
bboy_RES's Avatar
i think it should be fine. i just finished my clutch install a 1 1/2 weeks ago and the driver side axle looked similar to that. i have about 1k miles on the new clutch and everything seems fine. i hit the end of the axle with a rubber dead blow hammer to make sure it was seated as much as possible. just make sure you're not able to pull it out with your hands which you obviously did already.
Old May 29, 2008 | 10:05 AM
Evo9tunerz's Avatar
Awesome thanks, I just needed another person's opinion.
Old May 29, 2008 | 06:58 PM
MitsuJoe's Avatar
Make sure the inner circlip on the output shaft is not defective. I have broken one of these before and had to replace it. You want to be sure that the seal is made and that the axle won't dislodge and then a loss of fluid could occur. Better to disassemble and inspect than risk it down the road.
Old May 29, 2008 | 07:37 PM
Evo9tunerz's Avatar
How do I tell if the circlip is defective? It's not broken or bent in an unsual way. The only thing that I am worried about is if t-case fluid leaks out.
Old May 29, 2008 | 07:53 PM
MitsuJoe's Avatar
There is in inner circlip on the output shaft from the t-case. This is what you want to check.
Old May 30, 2008 | 09:05 AM
Evo9tunerz's Avatar
So do I pull the output shaft out from the t-case, just like how I pulled the shaft from the tranny?
Old May 30, 2008 | 09:45 AM
MitsuJoe's Avatar
Yes it is just like the one that came from the tranny side.
MitsuJoe
468
Feb 20, 2016 11:17 AM
stunna2o1
12
Jan 19, 2016 11:44 PM
halfnhalf83
31
Oct 7, 2015 08:23 PM
Ev0cRaZy
Apr 17, 2008 04:49 AM
MitsuJoe
Aug 1, 2004 01:59 PM
