Which order to install?
Old May 29, 2008 | 06:03 PM
Inflation's Avatar
Okay so I have a few things to put on my car this weekend and I just wanted to find out the best order to put them on so that I don't have to remove one to put the others on.
Here is the list
LICP
Forge MBC
02 Housing
Downpipe
Boost gague
Walbro Fuel pump
Current mods are
Intake
TBE
Old May 29, 2008 | 06:07 PM
boostinjuice's Avatar
Well, first, if you have TBE then you already have a downpipe. (Turbo back exhaust). But if you dont, I would put the 02 housing and downpipe on first. Then the LICP. Fuel Pump is under the backseat. And then boost guage I would install last.
kanyonkid's Avatar
u have tbe yet ur installing o2 and dp? anyways... do the 02 and dp first,,, everything else dosnt really matter
Old May 29, 2008 | 06:10 PM
Kracka's Avatar
Since when are newbs calling catbacks (CBE) turbobacks (TBE)? I've been seeing this far too often lately on this board and on many others.
Anyways, I would do it in this order:
Remove stock downpipe
Remove stock o2 housing
Replace LICP
Install new o2 housing
Install new downpipe
Install MBC
Install boost gauge
Replace fuel pump
Old May 29, 2008 | 06:11 PM
Mistaken's Avatar
Old May 29, 2008 | 06:15 PM
keeler's Avatar
Boost Gauge
WIDEBAND
02 Housing
Downpipe
LICP
Walbro
TUNE
MBC
Old May 29, 2008 | 06:46 PM
Inflation's Avatar
That was my fault its not a Turbo Back Exhaust. Thanks for the input on the order. I figured 02 then dp but just wanted to make sure.
Old May 29, 2008 | 06:54 PM
kanyonkid's Avatar
have u ever installed an o2 before?? its a pain in the ****, for me at least.... take the turbo out to make it easy on urself... GL with the install!
Old May 29, 2008 | 07:55 PM
Inflation's Avatar
No I have never done it before. I do have a friend or two that might help who both have much more knowledge then I do.
