ebay radiator?
Old May 31, 2008 | 10:18 AM
SPOOLD's Avatar
ebay radiator?
well the coolant overflow hose fitting on the filler neck of my radiator got cracked clean off when i was working on my car. i've drilled and tapped a couple fittings to reconnect the hose but i'm skeptical how permanent of a fix it will prove to be. i was looking into a replacement used stock radiator when i checked on ebay and came across some of the generic aluminum so called race radiators.
http://cgi.ebay.com/ebaymotors/MITSU...m140235715312&
i've read up about the mishimoto but has anybody else tryed these? i'm mainly concerned with how well they flow compared to stock. the way i see it is if i'm going to the trouble of buying a radiator and swapping it out why not add a little bling while i'm at it? from the pictures it shows all of the necessary stock mounting points and i can't really see any reason why it wouldnt work short of crappy welds. any thoughts?
