how accurate is mr boost gauge
Old Jun 18, 2008 | 06:25 PM
kanyonkid's Avatar
how accurate is mr boost gauge if ur boosting past 1.5 bars? cuz it goes past it a lil bit so can i assume the ticks are there and its accurate?
Thanx!
Old Jun 18, 2008 | 06:47 PM
1d10t's Avatar
I wouldnt trust any gauge past where it is designed to read. And also it is not in Bar.
Old Jun 18, 2008 | 06:50 PM
Sassaphrass's Avatar
i'm boosting 26.4 lbs and the needle stops a little under halfway between 1.5 bars and 76 on the vacumn side, so i think it's pretty accurate
TouringBubble's Avatar
It's quite accurate for me ... I trust it to around 1.7 or so ... no marks but it's still really close. I've compared it to the JDM MAP sensor.
Billy@EnglishRacing's Avatar
no very accurate
Old Jun 18, 2008 | 06:55 PM
porsherules911's Avatar
that is correct, the guage doesn't read in bar. Its kg/cm^2 i believe. Whatever bar value you calculate turns out to be slightly less when you do kg/cm^2
Old Jun 19, 2008 | 11:21 AM
kanyonkid's Avatar
sweet , and i thought kg/cm2 was the same thing as bars... but ok cuz i only get to where 1.6 would be....
THANX do not respond to this anymore so it stays away from the top
Old Jun 19, 2008 | 01:05 PM
DocCola's Avatar
learn something new everyday, i thought the gauge was bar too. woops
Old Jun 19, 2008 | 03:53 PM
Jay644's Avatar
What??? I thought it was in bars also....so whats the psi equivalent of 1kg/cm^2??
Cause my ix only spikes to 1.15 on the gauge. No boost leaks either, already took it to a shop.
Old Jun 19, 2008 | 04:41 PM
just search google for a conversion. its a very slight difference.
Old Jun 19, 2008 | 06:15 PM
EVO8emUp's Avatar
The difference is minuscule. Mine is also very accurate, within .5psi. and a half a pound ain't s**t.
Besides, I just use mine for a reference.
Old Jun 19, 2008 | 06:52 PM
Jay644's Avatar
Is it possible that mine is off due to kinks in the vacuum line?
The shop I took it to put their own gauge on, ran the hose up the hood an through the window then drove around.
They told me it was spiking at 1.3-1.4 bars and tapering to 1.2. Is that average? Would my altitude affect boost, 4,500 ft?
Old Jun 20, 2008 | 06:49 AM
FJF's Avatar
FJF
Pressure conversion calculator:
http://www.lenntech.com/unit-convers...r/pressure.htm
