stock turbo and injectors?
You can run over 30psi on the stock injectors - that has nothing to do with how much boost you run on the stock turbo. What matters is octane - you need higher octane to run 26psi, and you don't need to upgrade the injectors to do that. Slap your friend in the face next time you see him for trying to get you to buy those injectors - lame.
You need a proper tuner and proper fuel to run higher boost. 23 should be fine on pump gas with the fuel pump and a good tune.
