help: door locks dont work after boost gauge install
Old Jun 20, 2008 | 08:15 AM
ScoobySAM's Avatar
I just installed my boost gauge and while installing the light wirings it accidentally grounded out making a few sparks. After that, everything went well. When i was finished i noticed my door locks didnt work. I checked all my fuses under the dash and under the hood. Everything is fine. Anyone?
EDIT: A/C or heater doesnt work either. The blower doesnt turn on at all for a/c or heater.
Old Jun 20, 2008 | 08:21 AM
Tnnrx7's Avatar
Where did you wire it at?
Old Jun 20, 2008 | 08:35 AM
avengerhed's Avatar
Is the door lock system completely down? Can you actuate the locks with the keyless entry remote? Or the button on the driver door? Passenger door?
If none of these mechanisms work, I'd say that you may have damaged the ETACS....or whatever the PCM/body control module is called in the Evo... If it's module-related, maybe pulling the battery cable and reconnecting it can help you...
Good luck...
Old Jun 20, 2008 | 08:52 AM
ScoobySAM's Avatar
i connected it on the fuse for the cig lighter. The door lock system is completely down. The parking lights will go on and off with the remote but the door locks dont work.
also, if the ETACS was damaged would the power windows still work? Because everything else works fine.
Old Jun 20, 2008 | 08:54 AM
andrewzaragoza's Avatar
im not sure but i bet there should be a fuse for the door locks. you might want to check it out. chances are you blew a fuse during the installation. you might have shorted something out.
Old Jun 20, 2008 | 08:59 AM
ScoobySAM's Avatar
The fuse for the door locks is fine. I checked it and swapped it out 3 times. It is under the dash
Old Jun 20, 2008 | 09:23 AM
ScoobySAM's Avatar
A/C doesnt work either...wtf???????????
Old Jun 20, 2008 | 10:07 AM
SpoolinK20's Avatar
make sure the ground is secure... it sounds like your losing constant and the ground is bleeding out somewhere. If this isnt the case check any places you may have tapped into any factory wires and make sure that area is secure and wrapped. if not try replacing the backup/accessory power fuse...
Old Jun 20, 2008 | 10:42 AM
wreckless969's Avatar
I hoped you learned your lesson about messing with the wiring with the battery still hooked up.
Old Jun 20, 2008 | 11:00 AM
avengerhed's Avatar
Check your fuses again... if the blower doesn't turn on it sounds like more of a fuse issue to me and not an ETACS issue. I'm not familiar enough with the electrical system on teh car to give you specifics but start with the fuses / links / relays responsible for the blower and go from there...
Old Jun 20, 2008 | 11:01 AM
avengerhed's Avatar
The fact that your lights flash when you hit the remote but the locks don't work makes me feel more confident that your ETACS is not damaged...but it's not an impossibility that only a portion of it got broken...
Old Jun 20, 2008 | 11:08 AM
CGroovy2k2's Avatar
+1 Sorry for the mishap but it sounds like a fuse or relay of some type
Old Jun 20, 2008 | 11:17 AM
ScoobySAM's Avatar
How do I know if a relay is bad
Old Jun 20, 2008 | 11:21 AM
Thegame's Avatar
You'll have to check continuity and take voltage readings. I can look it up for you exactly what to check. Hang on.
Old Jun 20, 2008 | 12:40 PM
ScoobySAM's Avatar
ok thanks..just borrowed a volt meter. I'll have to check it when I get off work. Its bugging me so bad
