just put 100watt fog light bulbs in
Old Jun 20, 2008 | 10:02 PM
bbyevo8u's Avatar
is 100watts to much stock are 55watts, are my harness plugs going to melt? it seems like they get really hot
Old Jun 20, 2008 | 10:06 PM
bbyevo8u's Avatar
i bought them from lancershop (artic white fogs) and they stated that they were 85watts "witch is still a little high" but when they came i seen that there 100watts i really dont know if the watts are to high came someone help me here
Old Jun 20, 2008 | 11:15 PM
SICK9's Avatar
I have the PIAA extreme arctic white fogs,[also from lancershop] and mine are "equal" to 110 watts, and mine have been fine for 2 years now..
I would just keep an eye on the harness and the headlight lens and make sure they aren't hot enough to melt anything..
Old Jun 20, 2008 | 11:22 PM
QwikEVO's Avatar
I had 100w bulbs in my SRT-4 and it melted the connector on my multifunction switch. The voltage was just too high.
It may be fine now, but after time it will melt your sh*t.
Old Jun 21, 2008 | 08:44 AM
bbyevo8u's Avatar
^^ thats what im thinking i dont know what to do i've been checking them i dont see melting but they are f**king HOT much hotter then the headlights!!.........sick9 do you always put your fogs on with your headlights?? thanks guys for the help
John
Old Jun 21, 2008 | 07:07 PM
redline7's Avatar
Originally Posted by SICK9
I have the PIAA extreme arctic white fogs,[also from lancershop] and mine are equal to 110 watts, and mine have been fine for 2 years now..
Should be fine..
If lancershop sells em, i doubt they would sell em if they hurt your car.
anyone else have any opinions?
I sell bulbs at my store and dont get confused with' rated as', and what they 'actually are'. PIAA are rated as and output 100W+ but at about 60W so they are fine. True 100W+ bulbs will generate alot more heat and will eventually almost certainly cause a problem and not one you can check beforehand. It could burn out the harness or worse in a matter of seconds.
Anyway the workaround is to usually put in a relay.
Learn more here...
http://home.howstuffworks.com/relay.htm
http://en.wikipedia.org/wiki/Relay
Old Jun 21, 2008 | 08:35 PM
porsherules911's Avatar
I'm running the yellow nokya fogs right now and I believe the package said they were 80w not sure but should I be worried about it melting the housing in the long run? When they are on they get hot just like the headlights.
Old Jun 21, 2008 | 09:08 PM
redline7's Avatar
80W would normally be the max I tell a customer to run but I would still check them regularly to be on the safe side.
Old Jun 21, 2008 | 11:24 PM
SICK9's Avatar
edit:
Just found this on an alternate site using the same part # from lancershop.
Part # nok7218 Product Notes:
1.) These bulbs are designed for maximum light output, therefore these bulbs may be higher wattage than your O.E. bulb.
Please make the necessary wiring upgrades before fitting these bulbs.
I would probably not run these particular bulbs with out a wiring upgrade..
On a side note the PIAA's are great. twice as much $ but same color.. Work for me
Old Jun 22, 2008 | 08:07 PM
bbyevo8u's Avatar
so you guys are saying my sh*ts going to melt
Old Jun 22, 2008 | 08:14 PM
whoang40's Avatar
if you don't want to worry about melting, try 3000K HID lights. Rated at 35watts, and 3 times brighter. They're really bright yellow. I got mine from ebay for like $65 shipped. This is cheaper or at price for PIIA bulbs.
Old Jun 22, 2008 | 11:22 PM
SICK9's Avatar
YES.
I would not run those bulbs.
true 100w bulbs will probably melt it and the headlight housing.
Find some diff. bulbs that are lower wattage but same color.
Old Jun 22, 2008 | 11:25 PM
QwikEVO's Avatar
Silverstars.
Old Jun 26, 2008 | 11:49 AM
sk8terdude929's Avatar
i would keep an eye on them, i had a buddy of mine put a higher bulb in and melted the lens from the inside. Just be careful
Old Jun 26, 2008 | 12:13 PM
SoundBoy4's Avatar
I'm running the same fog lights also from lancershop for almost a year now. I've used them a lot and haven't had any issues. Don't expect a blue hue to come from these though, they ARE whiter than the stock fogs but compared to the HIDs they do look a little bit yellower (see pic). In hindsight i probably should have waited and done an HID fog upgrade.
