Question about apexi turbo timer
Old Jun 22, 2008 | 11:58 AM
rickay726's Avatar
ok so i just bought the apexi turbo timer wiht the plug and play harness. how ever i searched everywhere and cannot find on my evo where to plug the harness in. sorry if this is a little noobish but im new to my evo and havent figured out where to install it. thanks
-ricky
Old Jun 22, 2008 | 12:07 PM
Spish's Avatar
I just installed mine a few weeks ago, just take off the steering column cover (3 screws) and you will see a white white connection, just disconnect and put the TT harness between the 2 connections. Here is a link to more info.
https://www.evolutionm.net/forums/sh...ad.php?t=75679
Old Jun 22, 2008 | 12:19 PM
rickay726's Avatar
yeah i saw that read up but didnt understand why i had to go into the glove box if i could do it under the steeing colum
Old Jun 22, 2008 | 12:48 PM
Spish's Avatar
You go under the glove box to jump the wire from the TT to the O2 wire going into the ECU, you don't have to use this feature, it will still work if you don't attach that wire. Plus if you have a IX the ECU is different and those pics of the ECU won't help. I've got mine ran without using the O2 signal and it works fine.
Old Jun 22, 2008 | 12:51 PM
Spish's Avatar
https://www.evolutionm.net/forums/sh...4&postcount=47
Link to IX ECU pinout
Old Jun 22, 2008 | 01:00 PM
DocCola's Avatar
Thanks for those links, I have been thinking about getting a TT and installing it myself, think I'm sold now.
Old Jun 22, 2008 | 10:32 PM
Spish's Avatar
Its cake, it takes longer to take off the column panel than it does to install. Good luck!
Old Feb 16, 2009 | 12:11 PM
armympjch's Avatar
ok, i seen the diagram for the EVO IX ecu now what is it that im looking to splice into? is it the O2 sensor? i understand where everything else goes but im just really confused on where the wire splices into on the ecu for the IX....
Old Feb 16, 2009 | 12:22 PM
asdfasdf128's Avatar
subscribed
Old Feb 16, 2009 | 12:24 PM
Hatemy7's Avatar
I paid to get mines installed.
Old Feb 16, 2009 | 12:38 PM
armympjch's Avatar
i know its super easy to install, i just dont want to mess with that ecu without being 100% sure on the wire that i need to use, the install write up for the EVO VIII show a pic with the wire, but i know its different on the IXs, and the only diagram that i seen for the IXs didnt say. just shows all the wiring maped out??
Old Feb 16, 2009 | 03:26 PM
lilevil's Avatar
i paid someone to install my HKS turbo timer he did it for real cheap but that was b/c he is a friend of mine :P
i tried to read the instructions but i couldn't get it i have a fairly good knowledge on cars but electronics in cars are deff my weakest point :P
Old Feb 16, 2009 | 05:07 PM
EvolNinja's Avatar
Should have paid me to do it for you. I'll do it for a six pack of BudLight
But yeah, it shouldn't take long or hard. Just follow the How-To's direction and you'll be fine.
