Big Problem!!
Old Jun 26, 2008 | 08:21 AM
BootScraper88's Avatar
Big Problem!!
Hello I ran into a problem with the gt30 kit im installing.I cant find a lower ic pipe that will work without buying a whole turbo kit.Can nyone please help me cause i gotta get it done quick thanks!
Old Jun 26, 2008 | 08:22 AM
TeStUdO's Avatar
What intercooler/turbo kit do you have?
Old Jun 26, 2008 | 08:29 AM
I have a xs power intercooler and a gt30r turbo
Old Jun 26, 2008 | 08:32 AM
TeStUdO's Avatar
Ok, who makes your turbo kit?
Old Jun 26, 2008 | 08:35 AM
i bought the o2 housing and exhaust manifold from peakboost. I kinda didnt buy a full kit but pieced one together.
Old Jun 26, 2008 | 08:39 AM
TeStUdO's Avatar
So what LICP are you using?
Old Jun 26, 2008 | 08:41 AM
Dr Crash's Avatar
the XS Power i/c is from ebay, i have the same one. They supply i/c piping, but not the lower for some stupid reason. i managed to use the oem evo viii pipes and make it work, but it takes time and some "trimming" of piping to make it work.
Problem is that the upper they give you doesn't fit with other lowers as it was made for oem replacement and most others are full replacement. Though, the lower fitment issue has nothing to do with the turbo kit you're running since the lower is between the i/c and upper and therefore does not need to connect to the turbo in any way, so I don't really see the problem here.
Old Jun 26, 2008 | 08:48 AM
gsrboi80's Avatar
Your likley going to have to get one made any reputable exhaust shop can do this easily
Old Jun 26, 2008 | 08:53 AM
well i bought the car with that intercooler already on it but the lower ic is too short to run to the compressor housing of the turbo thats my problem
Old Jun 26, 2008 | 08:56 AM
gsrboi80's Avatar
Any LICP pipe you buy in the after market (If not from a turbo kit) is going to be for fitting it to the stock turbine outlet pipe and IC inlet.
Just go to a performance shop and get a piece of stainless bent up Call it a day
Old Jun 26, 2008 | 08:59 AM
all right thank you for ur help U R A GOD IN MY BOOK
EvoKnievo's Avatar
dude this reallly isnt a problem anyone online can help you with. you just need to get the correct piping and fab a licp. if your piecing together your own kit what did you expect? it wont require anything more than a 180 bend and ruffly a 90 bend and 3 couplers.
