where to get a reducer...
Old Jun 26, 2008 | 09:27 AM
EvoJoeIX's Avatar
hey guys i have ordered the dejon intake tube. from what i understand you need a reducer to run this on the stock turbo. could anyone tell me the size of the turbo inlet on the stocker? and does anyone know where i can get the reducer? thanks
Old Jun 26, 2008 | 11:21 AM
sk8terdude929's Avatar
i would call a parts place that deals specifically with evos and dsm's. i know its not around you, but its a local store for me and they have helped me a good amount. they also have a online store www.extremepsi.com They should be able to give you an exact answer
Old Jun 26, 2008 | 08:27 PM
EvoJoeIX's Avatar
thanks ill try there
anybody else?
nobody knows the inlet size on the stock turbo
Old Jun 26, 2008 | 08:45 PM
bao's Avatar
bao
yeah, i also need to know.
Old Jun 27, 2008 | 08:07 AM
bao's Avatar
bao
ok. guys at extreme psi said that it might be 2.5" but they are not 100% sure though.
Old Jun 27, 2008 | 08:49 AM
BlueEvo61106's Avatar
It is 2 inch inlet. That is what a local shop told me. I researched it and someone measured and took a picture and it said 2in.
Old Jun 27, 2008 | 09:10 AM
EvoJoeIX's Avatar
okay not my next question would be does anybody know where i can get a coupler that will fit the stock turbo and fit this intake pipe? i know they have to make them.
Old Jun 27, 2008 | 10:11 AM
bao's Avatar
bao
measure your dejon intake then look up extremepsi for sizes.
Old Jun 27, 2008 | 10:22 AM
EvoJoeIX's Avatar
i did they dont have a 4in. to 2in.
i did email them to see if they can make one or get me one. ill give you an update when i hear back from them
Old Jun 27, 2008 | 10:24 AM
EvoJoeIX's Avatar
okay, i just hear back from them
they said the closest they have is a 2.25 to 4in.
is the close enough to work with the stock inlet?
Old Jun 27, 2008 | 10:26 AM
EvoJoeIX's Avatar
http://www.extremepsi.com/store/cust...cat=930&page=1
it says it works with the 16g on the DSMs
do you guys think it will fit?
Old Jun 27, 2008 | 12:28 PM
EM1 to EVO's Avatar
Why did you buy their 4" hard pipe? They make a 3" hard pipe. It would definitely be easier to find a 3" to 2" reducer, not to mention it would probably flow better since you're not trying to cram 4" of air into a 2" opening.
Old Jun 27, 2008 | 05:16 PM
turbolarry's Avatar
The stock turbo inlet is 2.5 inches.
The Dejon pipe is three inches.
A 3.0 to 2.5 reducer will work but it will rub on the lower radiator hose. I have one, but don't run it because of the rubbing.
Old Jun 27, 2008 | 05:17 PM
SOEuro's Avatar
home depot or lowes
Old Jun 27, 2008 | 05:18 PM
CaliMR's Avatar
You might be able to use the pipe reducer from Home Depot like people use when they do a boost leak test from the front of the turbo instead of the pipe on the bottom
