rpm drop????
Old Jun 29, 2008 | 10:21 PM
evotuner04's Avatar
15 Year MemberLikedLoved
rpm drop????
okay so i was driving around the other day and floored the car in 2nd gear and the rpms dropped from 4500k to around 3700k or so and then continued to pull hard all the way to redline...and it did it again in 5th gear at 5000k and dropped to 4500k
anyone know what this might be? and im not tuned either, which isnt a thing lol i've only had the 10.5 hotside, o2 housing, and exhaust mani for about 3 weeks and everything else has been on for awhile so idk if its from the newer mods or what
Old Jun 29, 2008 | 10:23 PM
rlui0514's Avatar
Is your battery on tight?
Old Jun 29, 2008 | 10:25 PM
huevosrancheros's Avatar
You could be leaking some boost. Re-tighten and check all your clamps.
How do you like your meagan headder????
Old Jun 29, 2008 | 10:27 PM
dac001's Avatar
Clutch??? IDK
Old Jun 29, 2008 | 10:29 PM
whoang40's Avatar
I would never floor the car until I'm tuned. It's not worth to have some fun then blow your engine. You'll have to log the car using evoscan or have your tuner look at it when it comes time.
Old Jun 29, 2008 | 10:31 PM
evotuner04's Avatar
the header is good...and i forgot to add that i do have a bad butterfly valve on the throttle body...i had a boost leak test done a few weeks ago and it showed up leaking but idk if that would cause the car to drop like that and then pull hard again
the battery is good and tight but theres no signs of it loosing battery power just a drop in power real quick so hmm????
Old Jun 29, 2008 | 10:34 PM
evotuner04's Avatar
im only at around 21psi maybe 22 which isnt even fuel cut and i dont get on the car too much just every now and then...bascially im not doing any differently then a lot of evo guys do or a lot ppl in general lol
Old Jun 29, 2008 | 10:40 PM
Warrtalon's Avatar
Your RPMs aren't going down - they're shooting up and then falling back down when the clutch grabs.
Clutch is slipping.
Old Jun 29, 2008 | 10:41 PM
evotuner04's Avatar
are you serious????? damn it
Old Jun 29, 2008 | 10:45 PM
Warrtalon's Avatar
You really can't feel it?
Old Jun 29, 2008 | 10:50 PM
evotuner04's Avatar
well if it is slipping it must have just started cause it ran strong just two weeks ago...so crap i have to buy a new clutch
Old Jun 29, 2008 | 11:03 PM
evotuner04's Avatar
is there anyway that my warranty will cover the clutch even tho my mods? im guessing no but maybe
Old Jun 29, 2008 | 11:05 PM
Warrtalon's Avatar
Well, any slipping clutch has a point in time at which it starts. You should go test it just to be sure. Get in 5th at 2500rpm and floor it. If the rpms jump up right when boost builds without you accelerating hard, then the rpms drop back down and you accelerate normally, then you know the clutch is slipping. It will happen worse in higher gears.
Clutches are wear items - they are not covered unless it's a manufacturer's defect, which can only be claimed within the first 12k miles. Even within that time, if they see mods or any hot spots on the flywheel, it won't be covered. It has to be something physically wrong with the clutch assembly. You are way beyond that stage.
Old Jun 29, 2008 | 11:14 PM
evotuner04's Avatar
i sure am...flippidy do crap!!!! meh a better clutch will...what do you think would be a good one...im planning on going to a gt35r next summer and full aem engine management system...and 272 cams soon...possibly meth injection but probably e-85
Old Jun 29, 2008 | 11:59 PM
Odenl0ki's Avatar
Sounds like a clutch problem to me.
