Power for Wideband
Old Jul 11, 2008 | 08:24 AM
Jp7's Avatar
Jp7
Power for Wideband
I took out the MR triple gauges in my car and I am wiring in a set of 3 gauges in its place.
I plan on using the same sources for power, and ground.
I am installing:
1 - An autometer voltage gauge (just like stock)
2 - An autometer oil temperature gauge (just like stock)
3 - An autometer wideband
The wideband has a heater (like they all do) and I was wondering if you think its safe to run that off of the same power line (red wire) - My fear is that i will blow a fuse because the heater draws too much power?
Old Jul 11, 2008 | 08:29 AM
selp's Avatar
use the cig ligher.
easier and no problems if there is so to be one
Old Jul 11, 2008 | 08:30 AM
06MRV8Killer's Avatar
Then run the power to the yellow wire under the left side kick panel on the driver side if you are worried
thats where mine is
Old Jul 14, 2008 | 11:46 AM
Elmo's_EVO_MR's Avatar
cig lighter will do the trick if nething use a bigger fuse...
Old Jul 14, 2008 | 11:52 AM
GTijoejoe's Avatar
Originally Posted by Elmo's_EVO_MR
... nething use a bigger fuse...
I hope you are kidding, this is horrible advice and a good way to cause an electrical fire with high gauge wiring if you really don't know what you are doing.
In addition, I run my ZT2 WB off my MR guage source.
Old Jul 14, 2008 | 12:24 PM
Jp7's Avatar
Jp7
Yeah, I just hooked them to the red wires in the spot where I de-wired my MR gauges (which are now for sale hint hint) - Drove 500 miles with it this way the other day and no problemo.
I noticed that when I am cruising and then I get off the gas to just drift to a slower speed she goes way lean (16) I am assuming this is just because the engine is basically idling down and dosent use much fuel right?
Old Jul 14, 2008 | 04:19 PM
gsrboi80's Avatar
Yea of course the wideband will go full lean when off the gas untill it gets back down to idle
Old Jul 14, 2008 | 05:48 PM
GTijoejoe's Avatar
As you decel in gear the ECU goes into fuel cut and the a lean condition will occur.
If you search there is an entire thread discussing this. 100% normal, usually ppl who have never used a wideband start to worry when they see this.
Old Jul 14, 2008 | 05:58 PM
Jp7's Avatar
Jp7
Oh I know that just because I put in a new gauge doesn't mean my car is running wrong, I was just looking for more of the reason of what is going on.
It does jump around a bit though, typically between 14.0 and 15.5
I was surprised about that.
Old Jul 14, 2008 | 06:38 PM
gsrboi80's Avatar
Yea itll bounce a little during cruise and idle. No worries under load is where it matters
