Gauge cluster lights going out
Old Jul 16, 2008 | 12:31 PM
TKEVO's Avatar
Veteran: Air Force
My lights behind RPMs are slowly fading out and I can't see half of the gauge. Also the lights behind my "Lancer" logo, temp gauge and fuel are complety out along with my speedometer bulbs are fading out.
Can anyone give any advice on the bulbs to replace them and how? Any help would be appreciated.
Old Jul 16, 2008 | 03:09 PM
AznEvoIX's Avatar
You should get some overlays. Fix that problem real quick. =)
Old Jul 16, 2008 | 03:15 PM
TKEVO's Avatar
Veteran: Air Force
Overlays?
Old Jul 16, 2008 | 03:40 PM
gsrboi80's Avatar
Take the cluster out all the bulbs are in the back
Old Jul 16, 2008 | 03:46 PM
TKEVO's Avatar
Veteran: Air Force
i know that much. does anyone know the bulb part #?
Old Jul 16, 2008 | 03:52 PM
FloopyDisk's Avatar
Originally Posted by TKEVO
Overlays?
http://cgi.ebay.com/ebaymotors/ws/eB...m=110268426986 Lights up blue
http://cgi.ebay.com/ebaymotors/ws/eB...m=110269477047 Lights up white.
There is non-acd models.
I'm still deciding on color. Contact Trustz on this forum.
Old Jul 16, 2008 | 03:54 PM
Curt@MrLed's Avatar
Former Vendor
If you want your cluster red and not orangish, I have them in led's. Pm me if interested.
Old Jul 16, 2008 | 05:09 PM
ev0srule's Avatar
It honestly sounds like a ground wire issue, all the bulbs would not go out at the same time. Also make sure you dont have a blown fuse anywhere, but usually a dimness is caused by a weak ground
Old Jul 16, 2008 | 06:27 PM
def1's Avatar
this happened to me. This worked for me it might work for u. Its easy to do so its worth a try. Take out the whole gauge cluster and check if your lights have gone loose. If not go get them from the dealership they should not be more then 8 dollars
Old Jul 16, 2008 | 07:06 PM
gaylantvr4's Avatar
they are problity 194 bulbs.
Old Jul 16, 2008 | 07:09 PM
TKEVO's Avatar
Veteran: Air Force
All the lights didn't go out at the same time.
Old Jul 16, 2008 | 07:10 PM
TKEVO's Avatar
Veteran: Air Force
Well in my case the nearest dealership is 45 miles away. I'll rather walk than to pay gas....
Old Aug 2, 2008 | 02:21 PM
TKEVO's Avatar
Veteran: Air Force
Any other inputs to this lighting issue. Where can I purchase these bulbs at,... etc??
Old Aug 2, 2008 | 02:59 PM
yellowebo's Avatar
MitsuParts.com has the ones you need. Just replaced the same exact bulbs.
Old Aug 2, 2008 | 03:46 PM
TKEVO's Avatar
Veteran: Air Force
About how many do I need?
