Evo + HKS 272 camshaft = upgrade valve spring?
Old Aug 1, 2008 | 08:56 AM
EvolNinja's Avatar
Ok, I know that most people would upgrade their head studs? Some says that it requires valve spring upgrades too. Is that necessary?
Old Aug 1, 2008 | 09:00 AM
bluebanana23's Avatar
no, not even withthe 280's . Why? It has stock lift or close to it.
Old Aug 1, 2008 | 09:03 AM
alan678's Avatar
They are recommended but not required with the HKS cams.....
but they SHOULD be done for added safety when revving past 7.5k rpms...
Old Aug 1, 2008 | 09:45 AM
mullen's Avatar
They Should Get Done But I Havent Done Mine Yet, Plan To In The Near Future
Old Aug 1, 2008 | 09:55 AM
06MRV8Killer's Avatar
Go and do it without upgrading, blow some crap up and lift some valves and smash some pistons and get back to us and let everyone know how it went.
BTW, your tuned by Tamer and so am I he knows what he is talking about, talk to him and get his .02 cents and he will most likely tell you to do the upgrade, your playing with fire not doing it.
Old Aug 1, 2008 | 10:10 AM
I've been tuned by Dynoflash, turbotrix, and KevinD. All of them said it's not needed unless you rev very high. I.e. beyond 7800 RPM. I've driven 30,000 miles, without upgrading anything head wise, with the exact cams and I'm fine just like countless others.
Old Aug 1, 2008 | 10:11 AM
skoarpio's Avatar
honestly if your going to upgrade cams bro, do it right the first time. No you dont need to but I would.
Old Aug 1, 2008 | 10:13 AM
riceball777's Avatar
i' have hks 272 with stock valve springs and stock head studs and i been fine for 50k miles and so have countless other people
Old Aug 1, 2008 | 10:37 AM
GinNBoost's Avatar
The stock turbo runs out of steam at 7k RPM. Why anyone would rev higher than that is beyond me.
Old Aug 1, 2008 | 10:42 AM
rahku's Avatar
yea im getting mine put in soon but i dont plan on doing springs i shift before 7k anyways
Old Aug 1, 2008 | 10:45 AM
highbredcloud's Avatar
I don't have experience with the eVo cams...however, I have built ford motors before...When putting a cam especially with with more aggressive ramp rates and durations it was always recommended to upgrade springs for simply because some cams require a stronger seat pressure...not sure how the stock pressure compares to the stock cam vs HKS...but that was something that was important...you get more out of the cam with proper springs...and you don't risk valve float if you accidently over-rev the car...so it may not be neccessary per say but its nice to have a piece of mind knowing that your safe especially when so much damge can be caused by negligence...just my $.02
Old Aug 1, 2008 | 10:49 AM
ray3328's Avatar
with HKS 272 cams you don't need springs and retainers unless you plan to rev past 8k rpm... had mine for 20k miles no problems, there are plenty of people running the HKS 280's with no problems also...
Old Aug 1, 2008 | 10:56 AM
DSMunknown's Avatar
Don't see the need for HKS when DKS is offered.
Old Aug 1, 2008 | 01:49 PM
EvolNinja's Avatar
Thanks a lot for your comment guys!
Old Aug 1, 2008 | 01:55 PM
skoarpio's Avatar
ehat ya gonna do, stock or build it?
