help emergency!!
Old Aug 5, 2008 | 07:17 PM
def1's Avatar
help emergency!!
I just drained my t-case fluid just to find out my fill plug is stripped and cant come off! I cant leave it like this and i cant drive it anywhere to be fixed. Is there any easy solution. i want to fix it before tonight.
Old Aug 5, 2008 | 07:24 PM
gsrboi80's Avatar
They make special sockets to take off stripped bolts
Old Aug 5, 2008 | 07:47 PM
1d10t's Avatar
You may be able to break it loose with a chisel and hammer, but probably not. Either way, it needs to be replaced. Go to kmart or sears and see if craftsman makes an easy out that size--only 23 ft/lbs next time!
Old Aug 5, 2008 | 07:48 PM
def1's Avatar
this is my first time chaning my fluids the car is used so whoever the idiot that was that owned the car before did this. im pissed off. i was suppose to have this all finished in 45 minutes and be on my way to have a few drinks and im stuck here for 2 hours messing with this ****
Old Aug 5, 2008 | 07:51 PM
1d10t's Avatar
It will make the drinks taste better lol. You could try vise grips, or a smaller socket.
Old Aug 5, 2008 | 08:54 PM
def1's Avatar
ah i finally got it. just had to hammer on the socket and grab a wrench and force that **** off with some ***** ha. and o yes those drinks well taste sweet after all this work. Thanks guys for the responses. I still gotta do my rear diff and tranny oil now too but ill do that tomorrow morning its time to get some drinks *cheers*
Old Aug 5, 2008 | 08:59 PM
adrock353's Avatar
nice work. Torque wrench is an invaluable tool
Old Aug 5, 2008 | 09:01 PM
EvolNinja's Avatar
Weren't you suppose to remove the fill plug before removing the drained plug???
Old Aug 5, 2008 | 09:29 PM
def1's Avatar
i actually had a torque wrench but i borrowed one from autozone cuz i didnt feel like buying one and they gave me like a huge 3 foot wrench so the jack i had didnt give me enough leverage to work with it so i had to use ****ty wrenchs and sockets and ratchets blah!! and it didnt help that the bolt was practically rounded at the top.
and yes it seemed like the smart thing to take the fill plug off but i completely forgot so o well a lesson learned. tomorrow taking off the fill plug will be the first thing i do
Old Aug 5, 2008 | 09:40 PM
def1's Avatar
actually maybe im the idiot now haha. I forgot to take off the metal shavings off the drain plug. I was so frustrated about the stupid fill plug that i forgot to clean the drain plug. You think it would be fine? I honestly dont remember even seeing any metal shavings on the drain plug. Would i be fine this one time without doing ti?
Old Aug 5, 2008 | 10:07 PM
def1's Avatar
anyone?
Old Aug 5, 2008 | 10:10 PM
bluebanana23's Avatar
most likely you'll be fine but there's usually a lot of shavings...
Old Aug 5, 2008 | 10:15 PM
def1's Avatar
yea man i completely just forgot. I took it off and put it aside and when i finally got the damn fill plug off i just hurried and put the drain plug on so i could pump the oil and be finished. I didnt really take a good look at it but who knows maybe there was a lot of shavings. But i really dont want to ahve to go trhough the whole mess of draining the oil again and pumping it again just to take off some metal shavings unless its an absolute mush
Old Aug 6, 2008 | 04:34 AM
gsrboi80's Avatar
The shavings will stay stuck to the magnet man no worries . Just remember to clean them off next time
