Need help ASAP!!!!!!
Old Aug 12, 2008 | 11:51 PM
3star2nr's Avatar
I need the turbo from a 1999 Lancer GSR with the 4G93T engine.
Its a TD04L 13G but a very special one, I know of no other car that uses this turbo. I need one ASAP, please let me know if you can find one of these.
Heres the pat number for the turbo
49377-02100
The Eclipse turbo will not work, nor will the JDM 3000GT turbo. It has to be this part number.
Please if you can help. I know this may not be the rigght board, but GSRs are confusing, they arent evos and they arent lancers!?!?!?
Thank you
Old Aug 12, 2008 | 11:56 PM
3star2nr's Avatar
Here are some Pics of the turbo
The 99GSR turbo vs the USDM TD04 13g from the eclipse
As you can see the back housing is very different from the USDM.
We tried to swap the back housings unto the USDM 13g, as TD04 wheels should be similar.
Then port and polished the compressor housing, as the USDM 13g is slightly wider
Does anyone have a direct link to parts from japan, I need this turbo ASAP
Old Aug 13, 2008 | 12:00 AM
3star2nr's Avatar
would swap in a TD05 but the 4g63 and 4g93T have different manifolds
Old Aug 13, 2008 | 05:16 AM
JdMeVo4's Avatar
The SRT-4 uses the TD04 also...
Arkitek
MitsubishiParts.net - WA
Mar 4, 2010 08:27 AM
CaseyR
Lancer Engine Tech
Jul 2, 2009 10:39 PM
SlowSportSedan
Dec 17, 2007 10:29 PM
haze1995
Northwest Region
28
Feb 6, 2006 01:39 PM
inariv5573
May 13, 2005 06:48 AM
