fuel pump install help
Old Sep 1, 2008 | 12:41 PM
kanyonkid's Avatar
this is my 5th fuel pump install for people, and when i took the pump out of the "pump casing"(whatever the big plastic thing is called) i pulled a lil too hard and the wires from the gray clip ripped out....
I stuck them back in and tried it both ways and the gas gauge nor pump is not working, Any ideas??
Thanx!
J
Old Sep 1, 2008 | 01:03 PM
kanyonkid's Avatar
bump, gotta get this car started!
Old Sep 1, 2008 | 01:04 PM
Billy@EnglishRacing's Avatar
make sure everything is connected and in there nice and snug. make sure both o rings are on right as well
Old Sep 1, 2008 | 01:34 PM
kanyonkid's Avatar
ok, got the car started, but gas gauge still doesn't work......
Old Sep 1, 2008 | 01:36 PM
something is still not connected right then
Old Sep 1, 2008 | 01:40 PM
kanyonkid's Avatar
hmmm, dam
Old Sep 1, 2008 | 01:44 PM
YzBrad99's Avatar
your gonna have to order a new harness for the pump clip. Not much you can do but rig it, but i dont recommend rigging these cars. They arent 3 thousand dollar civics.
Old Sep 1, 2008 | 01:45 PM
edardnaekim's Avatar
if you need that harness i have one laying around, did you knock the float out of place?
Old Sep 1, 2008 | 01:46 PM
its just reattaching a wire, its not rocket science.
Old Sep 1, 2008 | 02:26 PM
if it helps any the black wire is the one closest to the tab.
Old Sep 1, 2008 | 02:46 PM
bordo's Avatar
edardnaekin, the float was messed up, car is up n running perfect... thank you
inneedof, ur sarcasm was appreciated!
