Carpet soaked, WTF?
Old Sep 5, 2008 | 01:40 PM
Blitz's Avatar
Carpet soaked, WTF?
We had a lot of rain in Chicago yesterday and my car was parked outside during most of it. I got in to drive to school today and noticed that my shoes were slipping on the metal pedals. So I did what I always do when that happens: wipe my shoes on the floormat. But that didn't help. I looked down to see that the floormat is absolutely soaked with water, and worse yet, so is the carpet underneath it. Nothing else in the car is even slightly wet, just the carpet. And I mean WET. Enough to seep into the floormat even though the bottom is rubber.
All doors and windows were closed/locked tight throughout the storm, before anyone suggests it. So what could it be? My friend suggested a leak in the door seal somewhere. Is this a common problem for our cars? Anyone ever experience it? I'm going to take it to the dealer to see what they have to say.
Old Sep 5, 2008 | 01:45 PM
dek0026's Avatar
you know this may or may not be relevant but driving after sitting in a rain storm a crapload of water would just pour right out from under the dash by my clutch in my old srt4 (read: neon).
since you noticed it after you started driving maybe this is similar and it wasn't wet before you started moving the car around. remember we have big vents on our hoods and last time i checked they weren't waterproof.
Old Sep 5, 2008 | 01:57 PM
derekste's Avatar
there are some wires that come in to the cabin through the firewall (I think they actually come in through the driver's side wheel well).
there is a rubber bung on the firewall that lets these wires connect to stuff behind the foot panel by your left foot. You need to seal this bung good ASAP, because it can corrode the wiring harness and cause all sorts of nasty problems. Search for "electrical gremlins" to see how people have fixed it.
And yes, it was like a monsoon yesterday!!
Old Sep 5, 2008 | 02:03 PM
Tnnrx7's Avatar
Yeah it rained a ****load here in IL yesterday.
I think someone posted something similar to this a while back. Forgot what the problem was and can't find the thread right now but look it up.
Old Sep 5, 2008 | 06:03 PM
Brokenevo's Avatar
most american cars do not stop rain from coming in, the seals suck. If you want to stop it replace it with some good seals
Old Sep 5, 2008 | 06:24 PM
BlueDemon's Avatar
^? Did you just called the evo an american car?
Old Sep 6, 2008 | 01:41 PM
DDATuned's Avatar
It could be the water seals are bad. Check the back rug on the driver side. Its most likely wet too. The water travels toward the front and always stops under the damn drivers side rug. I don't know why. Maybe the car is at a slant? But I had this same situation happen to me with 2 seperate dsms.
-Remy
Old Sep 6, 2008 | 07:33 PM
Evolution8RS's Avatar
take a look at the firewall on the drivers side... The wiring harness from under the kick pannel will get soaked and corrode.. Then random crap like horns that dont shut off, wipers that randomly kick on, and such.......
Take a tub of silicone, and literally wipe it all over the black rubber piece on the firewall... i mean cover the entire thing making sure its a solid seal...
I had the problem about 4 months ago.. Reaked havoc on crap... There is a guy on here that is a Mitsu mechanic and took pictures of repairing one of these cars... Fix the problem quick, otherwise you have a crap-load of problems to come down the road....
Old Sep 7, 2008 | 10:37 AM
sonicnofadz's Avatar
Do you have a sunroof? If so, check that first. Also check the weather stripping on the door.
Old Sep 7, 2008 | 11:06 AM
dsmbruno's Avatar
i had the same problem happen to me a few times. the carpet on the front and rear on the drivers side would get soaked... i tried to see where it was coming from and nothing. I havent fixed anything, but it stopped getting wet for some reason...
Old Sep 7, 2008 | 02:07 PM
2006blkevo9's Avatar
I would look into the fenderwell wires. I had the exact same problems 2 weeks after i bought my evo brand new. I took it to the dealer and they looked at it and found that the gromlet was loostand allowed water to get through, and at the time that it happened it didn't even rain very much. The mitsubshi dealer near me is a really good place, they replace the carpet and my floor mat o my drive side, and sealed up the loose wires.
It hasn't happened since.
Good luck
Old Sep 7, 2008 | 02:12 PM
EVO Nit3m4re's Avatar
man I've never heard of that before, I'll make sure to start parking in garage more often
Old Sep 7, 2008 | 02:57 PM
EVO_SE's Avatar
it's you draining system which is located were your wipers are at. some times when you park under a tree that throws alot of leaves it starts to plug up. so when your car is parked for some time in the rain water starts to build up causing it to leak by the firewall. so in order to stop that from happing you need to take off the cover were the wipers are at take high pressure air and try to blow everything away.
Old Sep 7, 2008 | 05:39 PM
andreww238's Avatar
damn thats sh****y sry to hear that
Old Sep 7, 2008 | 08:36 PM
Kuslowski's Avatar
i too had a similar problem on my passenger side footwell within a month of buying my evo. Same symptoms, after a rain storm there was literally about 2 inches of standing water in there and under the seat going towards the rear footwell...i used a shop vac and sucked it out and it was ok till the next rainy day...Same puddle
So i took it to the dealership after reading some thread about someone having the same problem, and it being an issue with the rubber grommet where they just drill a hole to put the MR boost gauge line through and don't properly reseal it...
dealership found that exact same problem and sealed it for free, and gave me new carpets.
except they told me the leak was due to my aftermarket boost gauge
