oil change gone bad!
Old Oct 2, 2008 | 07:03 PM
EM1 to EVO's Avatar
Alright guys thanks for the replies. I know this is gonna eat at me until next oil change so I'm probably gonna try pull the drain plug out and cover the hole real quick. Wish me luck
Old Oct 2, 2008 | 07:08 PM
compscibOi's Avatar
You should be fine. Just replace the plug every other oil change. That's what I do.
Old Oct 2, 2008 | 07:51 PM
EvoJoeIX's Avatar
just take some rtv and put it around the edge of the plug until the next oil change.... it will keep it from leaking. then just put on a new crush washer when you change it again
Old Oct 2, 2008 | 11:07 PM
porsherules911's Avatar
I have yet to use a washer and mine is fine, no leaks at all.
Old Oct 2, 2008 | 11:18 PM
simons3z's Avatar
r u kidding me i've seen some vehicles with 200,000 and not once have they changed there drain plug. lol.
Old Oct 3, 2008 | 04:01 AM
rcheung's Avatar
I think he meant to say crush washer and not drain plug.
Old Oct 3, 2008 | 04:46 AM
meat_EVO's Avatar
dont have one on my X
Old Oct 3, 2008 | 08:32 AM
El.BlueEvo9's Avatar
Just put one on the next time.
Old Oct 3, 2008 | 08:36 AM
newMRevoNyne's Avatar
Use a clean drain pan, let the oil drain out and when it is emptied, get the crush washer on, put drain plug back on, and refill with oil....that way you dont spill any and make a mess.
Old Oct 3, 2008 | 09:18 AM
lapulapu's Avatar
torque it an extra 5-7 lbs and you'll be fine.
Old Oct 3, 2008 | 09:36 AM
Jedi_Gill's Avatar
FCOTM Winner
Fumoto Valve for the win.
Old Oct 3, 2008 | 09:39 AM
tweakdsm's Avatar
get washer, do not drive the car (why risking it) YOU CAN take the plug out and just make sure to put gloves on and plug it with your finger, put washer on and screw it back in, add some oil, done.
Old Oct 3, 2008 | 10:46 AM
cableguy5752's Avatar
Originally Posted by bso
If you use a vacuum on the oil fill hole (shop vac with a rag covering the nozzle), than no oil will come out when the drain plug is pulled out. Old taxi drivers trick I seen before.
we used to do this from time to time when i worked at a lube shop. and it worked fine everytime. and actually my evo didnt have a washer for the first 50k miles or so. and never had a leak. but i did end up buying a pack of washers from oreillys though.
Old Oct 3, 2008 | 12:35 PM
EvoJoeIX's Avatar
do you have one on your evo?
how do you like it?
any problems with ground clearence/ leaking?
and where did you buy it from?
Old Oct 3, 2008 | 01:40 PM
Eviil8's Avatar
you will be fine without one, its not a big deal at all.
