Question with BOOST!
Old Oct 8, 2008 | 08:05 PM
Fast-Mover's Avatar
Ok i finaly got my car back toghter and did something very stupid.... I hooked the boost lines up the wrong way and drove the car for maby 2-3 mins with maby 2 pulls befor i relized my factory boost guage WAS MAXING OUT! I dont know how many pounds i probably pushed through her, i stopped right away and fixed the problem and she is running Just fine.
My question is could i have screwed something up in those few seconds?
Could i have done something that i wont see for a little whil;e down the road?
Any comments would be fine
Old Oct 8, 2008 | 08:15 PM
wevo1985's Avatar
do u have any tune or anything? i hit a fuel cut if my boost is to high or i start running lean.
Fast-Mover's Avatar
i am tuned yes
Old Oct 8, 2008 | 08:16 PM
wevo1985's Avatar
did u have any kind of miss when on it?
Old Oct 8, 2008 | 08:18 PM
Fast-Mover's Avatar
no missfire she JUST PULLED All the way through.... amazing feel, but i dont run meth so im worried
Old Oct 8, 2008 | 08:21 PM
Evo8luva's Avatar
if the car still seems fine, doesnt sound different your probably ok... if you want to look into it further do a compression/leakdown test
Old Oct 8, 2008 | 08:22 PM
wevo1985's Avatar
im sure everything is fine
Fast-Mover's Avatar
WHats the worst case thing that could have happened?
Old Oct 8, 2008 | 08:25 PM
wevo1985's Avatar
worst case is u crack a piston, but your car runs good now though.
Old Oct 8, 2008 | 08:28 PM
bluebanana23's Avatar
You probably hit around 26 psi, and the motor probably started to pulling timing to protect itself. More than likely you are fine.
Old Oct 8, 2008 | 10:45 PM
Oki Panoki's Avatar
i just hooked up a new boost gauge the other day. i used a different vacuum line, the one everyone says to use, and my gauge went all the way up to 2bar real quick. i turned down the mbc so it was going off the wastegate, around 12 psi and it still was at 2bar. i switched the gauge to another line and it reads perfect. idk what was up with it but for some reason that line caused it to read super high boost???
Old Oct 8, 2008 | 10:50 PM
importjake00's Avatar
I am sure your fine if your car is running fine right now.
