Gas tank won't stop leaking?
Old Oct 9, 2008 | 05:38 PM
Nvr2old32's Avatar
I just drained my gas tank to get the E85 out and put 94 in for the winter but for some reason, I can't get the tank to stop leaking. It's a very slow leak, a drop every minute or so. The bolts aren't stripped and are very tight. Is there something that might work to seal the bolts up? Something like plumbers tape?
Thanks for the help!
Mike
Old Oct 9, 2008 | 05:44 PM
ak47po's Avatar
You solved your own problem tape it.
Old Oct 9, 2008 | 05:50 PM
Nvr2old32's Avatar
That's what I figured but just wasn't sure. I'm going to go try that now.
Thanks
Old Oct 9, 2008 | 06:13 PM
Nvr2old32's Avatar
Thanks
Fixed!
Old Oct 9, 2008 | 06:57 PM
JRB_EVO's Avatar
Mike, what the heck are you doing!!!???
Get it fixed and be safe buddy!!!
Old Oct 9, 2008 | 07:10 PM
ray3328's Avatar
Had the same problem a while back, the washer was damaged from draining the tank many times. Changed the washer problem was fixed.
