Next Mod??
Old Oct 15, 2008 | 05:40 AM
  #31
FJF's Avatar
FJF
How about a driving school? It'll make you faster than any mod.
BTW, ditch the BOV (search for the HKS).
Old Oct 15, 2008 | 08:02 PM
  #32
90GSX-03EVO's Avatar
Originally Posted by wevo1
yeah so what cams put out the best power is it the hks 272's?
These.
Originally Posted by 90GSX-03EVO
Cams (FP4R or some Kelfords) and the stock Evo 9 diverter valve.
Old Oct 15, 2008 | 08:17 PM
  #33
ImJoey's Avatar
Keep the blow off valve. It makes me feel good to know there are a few ix's out there I can bully around. In all seriousness, cams should run you $350-$500 and the install should be no more than $200 from most installers.It can be done in less than an hour easily.
Old Oct 15, 2008 | 10:32 PM
  #34
wevo1's Avatar
ok well i went to ams today and even he said that my numbers were low because of the injen intake he said you get more power with the stock air box than with the injen. he said with the intercooler im pushin 300 - 305 now. and that i will gain 15 more hp with the stock air box with a k&n filter. but i asked him what he suggested that should be my next mod. he said to get the tomei cams for 450 and head studs for 190 and with install and a retune the total came out to be $950.00, and i will gain 35 - 40 whp and 25 - 30 more tq and will be a stage 3 evo.
Old Oct 15, 2008 | 10:37 PM
  #35
crckheadjed's Avatar
cams and meth
Old Oct 15, 2008 | 10:45 PM
  #36
eitan's Avatar
Injectors and E85.
Old Oct 16, 2008 | 04:02 AM
  #37
drop24's Avatar
Yeah, a stage 3 Evo with only 320 hp. Turn your boost up.
Old Oct 16, 2008 | 02:26 PM
  #38
ImJoey's Avatar
ok well i went to ams today and even he said that my numbers were low because of the injen intake he said you get more power with the stock air box than with the injen..
I used to be on the stock airbox bandwagon myself.If what you have typed above is true, please tell me how I made more power after switching out the stock intake setup with drop-in for the injen intake/uicp alone. I guess you have to try things yourself instead of always believing what you hear. Again, no other mods were done.Injen intake/uicp alone and my gains were almost 10whp over the stock setup.Maybe my stock setup was defective or leaking? Who knows. Do what works for you.Thats something youll learn with this car.Many routes to follow.Sorry for getting
Old Oct 16, 2008 | 07:59 PM
  #39
ernald711's Avatar
i'd go with cosworth cams. best for the mivec! that or suspension
Old Oct 17, 2008 | 12:30 AM
  #40
vicksen's Avatar
Suspension or brakes perhaps. If you're focusing on power maybe upgrading or porting your throttle body and intake manifold. Depending on it's availability, changing over to E85, all you'd need are injectors and a tune. Someone already suggested the EPM o2 housing. Perhaps under hood shifter bushings and drive line bushings. The list could go on and on.
Old Oct 19, 2008 | 07:33 PM
  #41
Gumby56's Avatar
suspension or cams but probably suspension ... yep suspension and then cams
