AEM boost gauge
Old Oct 19, 2008 | 09:44 AM
shawn360h's Avatar
AEM boost gauge
I am looking into to getting the AEM boost gauges(http://www.extremepsi.com/store/cust...cat=748&page=1) before i purchase this i got a few questions. first does the boost gauge run off some kind of sensor or is a vacuum tube like the autometer? If it does have a vacuum tube why does it cost 160 dollars more? If it does have a sensor can i log boost or can only a map sensor do that? i tried searching this topic but i can seem to find anything. any comments are appreciated thanx
Old Oct 19, 2008 | 12:23 PM
chaotichoax's Avatar
ever consider reading what it says?
**TAKEN DIRECTLY FROM LINK**
Originally Posted by extremepsi
AEM’s digital Boost display gauge delivers unsurpassed accuracy and visibility. Each gauge includes 24 color-coded (Red, Green, Yellow) LED lights that change from green to yellow to red for immediate reference to the measured parameter, and an integrated thee-digit display that reveals real-time operating conditions.
AEM’s digital display gauges feature a standard 52mm gauge housing that fits in most gauge pods and can be remotely mounted virtually anywhere. Each gauge includes interchangeable silver and black bezels and black and white faceplates to personalize the look of your gauge—it’s like having four gauge designs in one!
Gauge pressure range -30-50psi and 0-150psi
Includes easy-to-install harness and sensor
Complete stand alone gauge requires no additional sensors or programs to operate
Ideal for both fuel injected and carbureted motors
LED displays provide precise reference to critical operating conditions and alert driver of potentially damaging operating conditions
Includes 0-5V analog output for routing to engine management system or data logger
Easy to read faceplates/displays are designed to complement existing AEM gauge styles
Included bezels and face plates allow you to personalize the look of your gauge
Old Oct 19, 2008 | 12:34 PM
Celica2EVO's Avatar
Its a great guage, as I have it! It runs off of a map sensor and has an output wire.
Old Oct 19, 2008 | 01:09 PM
shawn360h's Avatar
so if i don't have a map sensor i can not use this gauge? i would have to get a aem ems to use it?
Old Oct 19, 2008 | 01:29 PM
JdMeVo4's Avatar
LoL "Includes easy-to-install harness and sensor
Complete stand alone gauge requires no additional sensors or programs to operate".
Old Oct 19, 2008 | 01:34 PM
there is your answer
Old Oct 19, 2008 | 02:17 PM
Maximum404's Avatar
Veteran: Navy
Would this be able to interface with a EVO X MAP sensor? I'd like to both display the pressure on the gauge and log it with EVOScan.
Old Oct 19, 2008 | 03:52 PM
Celica2EVO's Avatar
You dont have to use the map sensor in the hole on your manifold. It also includes a barb that you can run a vacuum hose onto. So you can use it as a map sensor, or you can use it as just an electrical boost gauge.
And it includes everything you need.
cpunlamd
May 6, 2014 04:08 PM
mattchan99
23
Jan 10, 2014 04:28 PM
jordan572
Jun 19, 2012 08:23 AM
nexium4
Mar 10, 2005 07:55 AM
LilJapnBoy
Mar 11, 2004 09:00 AM
