Clutch Noise? Help Plz
Old Oct 28, 2008 | 04:56 PM
KS_Evo9's Avatar
Well I just installed a ACT 6puck Unsprung and boy is it diffrent to drive. Well when I reverse and I start to release the clutch it makes a wierd noise kinda sounds if the clutch disk is rubbing on the flywheel like whiny dry noise..... I hope thats all it is ne1 else have this issue?
Old Oct 28, 2008 | 05:20 PM
gsrboi80's Avatar
Drive it easy for a couple days see if it goes away. Could be on the pedal arm itself grease it up a little
Old Oct 28, 2008 | 05:58 PM
KS_Evo9's Avatar
Its kinda hard cause its unsprung and im used to riding the clutch a little bit. It seems like with the unsprung its either in or out and if you ride it a little it makes that noise stated above. Ne1 runnin 6pucks and have this same problem or got info on it?
Old Oct 28, 2008 | 06:09 PM
1NASTYIXMR's Avatar
Did you install a new flywheel or resurfaced your old one?
Old Oct 28, 2008 | 06:51 PM
honeybadger's Avatar
Could it be the throwout bearing? they can get pretty noisy if they are on the way out.
Old Oct 28, 2008 | 07:50 PM
cosworthevo1133's Avatar
its just the clutch, when ur at a stop with the clutch in it sounds like a kind grind noise like its spinning, its just the clutch not broken in,i have the act hdss with streetlite flywheel pressure plate and its 6 pluck sprung, when i first got it, it did that till i fully broke it in, just drive it easy for 500 miles on street not free way and eventually it will go away
Old Oct 28, 2008 | 07:52 PM
Drooke's Avatar
haha its suppose to do that dont worry
