mbc install problem
Old Nov 16, 2008 | 10:52 AM
Anyevowilldo's Avatar
mbc install problem
Ok I have read for two hrs and can't get straight on this I just bought my car week ago and previous owner took the mbc off and left his lines on so I have 11 psi now I ran the t from the bov to the intake and ran that to top of mbc. Then I plugged the intake and ran the line from the wastegate to bottom of mbc, and looped the boost solenoid underneath intake with a small piece of hose, but no more boost still what do I do or what did I leave off?
Old Nov 16, 2008 | 10:54 AM
EvoJoeIX's Avatar
if you have mbc you dont use the boost solenoid thats on the car
its either one or the other. not both
Old Nov 16, 2008 | 10:56 AM
I didn't I looped a piece of hose to both nipples sory for the confusion
Old Nov 16, 2008 | 10:59 AM
EvoJoeIX's Avatar
oh okay
what mbc do you have?
Old Nov 16, 2008 | 11:03 AM
No name came with the car I wanted to make sure that fixed the prob bfore I got a hallman
Old Nov 16, 2008 | 11:19 AM
EvoJoeIX's Avatar
have you tried switching your lines around? maybe its backwards.
the car is only running on wastegate pressure, have you tried adjusting it? are you turning it the right way?
Old Nov 16, 2008 | 11:34 AM
I turned it like three times and made pulls and no more boost, I have a greddy type s bov recirculated is the screw on it do anything?
Old Nov 16, 2008 | 11:40 AM
The turbo nipple beside the waste gate gets capped right or no?
Old Nov 16, 2008 | 12:29 PM
Anyone???
Old Nov 16, 2008 | 12:34 PM
Psquared's Avatar
turbo outlet barb to the bottom of mbc ---then side of mbc back to wastegate. Cap off the stock boost control solenoids. Cap off intake barb on intake pipe.
is it an inline mbc or a forge type?
Old Nov 16, 2008 | 12:35 PM
kornkuu's Avatar
If you could possibley provide a couple of pics it would make it much easier for us to help you.
Old Nov 16, 2008 | 12:44 PM
sikrsix's Avatar
My mbc has the "T" from the bov line going to the bottom of my hallman, then the side of the hallman goes to the WG. The top nipple on the stock boost solenoid goes to the underneath of the intake, the other nipple is capped off. If you set it up like this, and have no boost increase, the no name mbc is junk.
Old Nov 16, 2008 | 12:49 PM
Kdash106's Avatar
follow this. https://www.evolutionm.net/forums/sh...d.php?t=116017
make sure u use new vac lines.
Old Nov 16, 2008 | 03:06 PM
Ok I just established that my mbc is junk by puttin on my buddys off his 240 and second I was under the impression the bottomof the mbc went to the wastegate
Old Nov 19, 2008 | 02:02 PM
RockmanX's Avatar
lol i have a forge mbc on my evo but i have not used it yet lol waiting for a tune but i installed it. If you need pics of a complete install when i do any mod i take pics of whole process for others like me that want to find a guide to go off of.
http://www.cardomain.com/ride/3123213
its on page 6 hope this helps some
