How To: Modding your Evo ~$100 at a time!
Old Jan 26, 2010, 03:17 PM
  #331
hpro350z's Avatar
cool post
Old Jan 26, 2010, 06:40 PM
  #332
paintballer419's Avatar
Step colder plugs can be a good mod?
Old Jan 26, 2010, 08:08 PM
  #333
Evo spec D's Avatar
so getting ready to do the clutch Exedy twin disk MM022HD
should I also do the "MR Machining Clutch Fork Stopper for Evolution 8 & 9" http://www.maperformance.com/mr-mach...m-cfs-evo.html
and "WORKS TKS Clutch Line Evo" http://www.maperformance.com/works-t...-line-evo.html
thanks for your opinion
Old Jan 26, 2010, 08:13 PM
  #334
Matt D.'s Avatar
Damn, finally found this thread. I've seen Kracka's car first hand and helped him a time or two before he left Minnesota. All of his mods are certainly doable on almost any budget.
Old Jan 26, 2010, 08:18 PM
  #335
teudmunki9mr's Avatar
legen(wait for it) dary.
Old Jan 26, 2010, 08:30 PM
  #336
Kracka's Avatar
Its a good idea if you're modded with increased boost over stock levels.
Old Jan 26, 2010, 08:49 PM
  #337
Kracka's Avatar
Old Jan 26, 2010, 08:52 PM
  #338
Kracka's Avatar
I definitely recommend the clutch fork stopper, it is a smart idea for anyone running a pull-type clutch (even stock). The SS clutch line would be an ok mod, but I honestly don't see it making any different unless you're running a really heavy pressure plate like the ACT 3200. Do it if you feel like spending the money and time, but if you do skip the Works line and just get the Technafit line since its the same thing only cheaper (you can special order any color you want at no additional cost).
Old Jan 27, 2010, 02:47 AM
  #339
Evo spec D's Avatar
^thanks for the prompt response,
if I do the "clutch line pill" mod, will we be in the same neighberhood where it will make sense to just do the clutch line as well or not even bother?
Old Jan 27, 2010, 09:53 AM
  #340
Kracka's Avatar
There is no pill in the clutch line, it is inside the clutch slave cylinder. Removing that pill doesn't make you even touch the factory rubber line since you just have to remove the hard metal line from the slave.
Old Jan 27, 2010, 10:09 AM
  #341
kyoo's Avatar
don't forget
https://www.evolutionm.net/forums/ev...available.html or other variants, and rear diff upgrades from tre or shep (or more expensive ones)
Old Jan 27, 2010, 11:46 AM
  #342
Kracka's Avatar
Originally Posted by kyooch
don't forget
I'm trying to keep this thread to only things I've actually tried and can vouch for, but I can assure you once I get any of those and like them they'll be added to the thread. I've been eyeing up that ACD reflash quite a bit lately though and think either that or a lightweight driveshaft will be my next mod.
Old Jan 27, 2010, 04:27 PM
  #343
mak1000's Avatar
good info to know thanks Kracka.
Old Jan 27, 2010, 06:05 PM
  #344
Evo spec D's Avatar
OK thank you very much for the clarification!!!......-how hard is it to do?
Old Jan 27, 2010, 09:42 PM
  #345
Kracka's Avatar
Removing the restrictor pill isn't a tough job; it can definitely be a messy one with all the brake fluid dripping to put a pan under the car and have some towels ready.
Quick Reply: How To: Modding your Evo ~$100 at a time!
