Passenger headlight removal???
Old Dec 1, 2008 | 09:06 PM
evoWWrs's Avatar
Originally Posted by Joshs EVO
Yes you need to remove the bumper and if I remember correctly there is 4 scews that hold the light on and then you just need to pull on it and it comes right out.
its 3.... 2 on top and 1 that the bumper covers!!!
Old Dec 5, 2008 | 10:44 PM
strtrcng426's Avatar
you should be able to get to it without removing the headlight or the bumper
Old Dec 9, 2008 | 10:13 AM
Evo8Master's Avatar
Originally Posted by MitsuJDM
No reason to completley remove the bumper. Turn the wheel to give yourself room and pull out some of the fender liner and you have access to the parking lights. It's cake.
Sweet!!! I'll give this a try
Old Dec 9, 2008 | 12:58 PM
rice_rocket88's Avatar
+1 turn the wheel and remove the bolt and 2 clips.. reach behind.
There is a long plastic end to it so it's very easy to grab.. long I mean an inch and a half or so.
I've had to do this three times on different cars. No sweat, 10 min job at most if you have to go back and forth for different sockets or screwdrivers... 5 mins if it's all in front of you
Old Jun 13, 2009 | 08:24 AM
hoof hearted's Avatar
Is that kinda like a "reach around"? lol
Gonna give it a shot right now....
Old Jun 13, 2009 | 09:08 AM
chrisevo8's Avatar
all i did was turn my wheel as well. got a little cut up but its cake.
Old Jun 14, 2009 | 07:01 AM
Like Dire Straits says..."That's the way you do it...."
DO NOT REMOVE THE BUMPER COVER UNLESS YOU ARE BORED....
Pull the inner fender back!
Took the wrong bulb out first... lol.
Replaced it with a good 'ol 194.
Now if I could just get my lights aimed HIGHER!!!!
I've tried turning the 10mm thingie but the cable that is SUPPOSED to be spun by the crap-*** plastic gear is bound up.
I'm pretty sure it is this plastic gear (via cable) that raises or lowers the light.
Old Jun 14, 2009 | 09:36 PM
bricel24's Avatar
There are 4 bolts that hold the headlight... 2 on top, 1 on the fender and 1 on the bottom corner above the crash beam end.
wowzers
Apr 11, 2014 04:15 PM
Lancerzz
Feb 7, 2012 06:12 PM
justintjustin
Dec 4, 2010 11:13 AM
ApexSilverXGSR
Evo X How Tos / Installations
Mar 2, 2010 09:29 PM
Black-X
23
Aug 10, 2009 01:31 PM
