Auto Spray mode
Old Sep 10, 2003 | 06:44 PM
webguy330i's Avatar
Originally posted by Alias
I wonder if it will make a difference if it is 115 degree out and I spray?
Depends on how much air is passing through the IC. If not a lot of air is flowing (i.e. low-speed driving and/or sitting still) it will probably evaporate before it gets put to use. If you're cruising at 50mph, I bet it will make SOME difference. The whole idea is to transfer heat from the surface/metal of the IC to the air via evaporation of the sprayed fluid.
