Steering Clunking noise help!!!
Old Dec 16, 2008 | 06:57 AM
Justindc2's Avatar
Question Steering Clunking noise help!!!
i have megan racing coilovers and it's been on for a year. Whenever it's cold outside it makes a clunking noise everytime i turn the wheel all the way to the right or left. noise comes from the right side and sometimes in the middle...
can someone help!?
Old Dec 16, 2008 | 07:00 AM
Tsurugi-san's Avatar
Sounds like one of your coils is blown --- right or left. I experienced a similar clunk on my old Evo 8, and that was a blown KYB --- and then I experienced it again on my MR --- which was a blown Bilstein (due to lowering springs). If I ever hear it again, I'm immediately having my coils checked.
Old Dec 16, 2008 | 08:36 AM
Draven83's Avatar
hmmm. i am having the same thing. i gotta get this looked at asap i think now. but its so hard cuz i am getting a whole new suspension set up in a few months
Old Dec 16, 2008 | 08:38 AM
staatz's Avatar
i have the megan coils too..and i noticed if I am parked and turn the wheel all the way to one side, i get like 2 clunks too. Could this be them also?
Old Dec 16, 2008 | 08:41 AM
evane's Avatar
i had a clunking/ clicking noise coming from my front driver side wheel and it was only when i turned the wheel and only when i was completely stopped or just pulling out...found out it was my stabilizer bar link on the end of the stab. bar....the bolt holding it on was loose so i tightened it abck up and the noise was gone...
Old Dec 16, 2008 | 08:55 AM
mifesto's Avatar
no it is not a blown coilover. jack up the side that is noisy, and you will see the double collar that sets/holds the preload for the spring is loose. loosen it more to get access to the portion that the spring sits and touches the top perch. you will notice there is a black plastic ring on top and bottom of the spring. over time those will have massive amount of dirt and pebbles stuck in there. clean them thoroughly(this can be done with the coilovers on the car). lub them up very well. tighten down the double collar(but not TOO tight).
this will significantly reduce the noise but dont forget these coilovers will always be alil noisy, especially in the winter.
Old Dec 17, 2008 | 03:04 PM
Justindc2's Avatar
thanks guys i;ll try it this weekend
jdogstoll23
May 9, 2016 09:34 AM
botemarc
15
Aug 6, 2015 01:21 PM
Sanny632
Sep 20, 2011 01:30 PM
MuslimEvoFreak
Nov 24, 2005 08:16 AM
platinumspecv
Dec 17, 2004 07:21 PM
