A couple idling issues....
Old Dec 22, 2008 | 05:38 PM
dorian7's Avatar
OK guys I have a couple of issues with the idle, I don't believe that they are related.
1st issue- I installed the Evo X BOV today and the car is acting like their is a vacuum leak, if I punch it then put the clutch in the rpms go way down and sometime it dies. I rechecked the vacuum lines and everything seems to be good.... I don't know does anyone else have this issue with the ix bov?
2nd Issue- If I turn the heater knob to defrost and turn the fan on the RPMs drop to 750 and it idles rough.... ???? Anyone else had this issue?
Edit/Delete Message
Old Dec 22, 2008 | 07:22 PM
dorian7's Avatar
Anyone?
Old Dec 22, 2008 | 07:33 PM
robevo8's Avatar
maybe some kind of voltage drop when the fan and heater is on, i know mine drops a tiny bit when thats all on... but not enough to make it idle rough
Old Dec 22, 2008 | 07:38 PM
NYC4g63IX's Avatar
rough idle= most common cause is a vacuum leak check your lines and the recirculation hoses on the BoV, and every other vacuum line possible e.g. pcv and egr and all that jazz
Old Dec 22, 2008 | 09:36 PM
EvoDom's Avatar
vacuum leak
