Forge UNOS MBC
Forge UNOS MBC
Hey Yall...
Well i need some help. I just installed my MBC today along with a APEXi mech. boost gauge... I know i installed everying correctly but I have the MBC set all the way down to the lowest boost setting possible... I cant stop boosting over 22 psi...i dont want to over boost.... Im tuned for 23.5 psi but idk if the ECU will control my boost if i have a MBC. I connected the lower vac hose to the wastegate.. and the one on the side to the intake mani. Did i do something wrong? or is everything okay? Your help is greatly appreciated.
Steven
Steven
you hooked them up wrong the bottom outlet of the mbc goes to the turbo nipple and the side port of the mbc goes to the wastegate nipple
take a look here
https://www.evolutionm.net/forums/ev...-unos-mbc.html
good luck
take a look here
good luck
MitsuJoe
Nov 19, 2006 04:21 PM
