2-Step Launch Control
Old Feb 14, 2009 | 10:08 AM
Phaeton008's Avatar
I'm having a difficult time understanding why the car would come from the factory with this feature when all it does (according to all the posts I've read) is eat up the internals of the car (cluch/tranny/etc.). Has anyone used the 2-step feature with and not found it to cause near immediate damage? Thanks guys.
Old Feb 14, 2009 | 10:11 AM
TeStUdO's Avatar
It's actually a feature built into the ECU so you don't destroy the t-case/tranny. The stock clutch/restrictor/clutch line also help aid in in the process.
Old Feb 14, 2009 | 10:14 AM
Craig King's Avatar
You need to do more research. Please use the search function.
Old Feb 14, 2009 | 10:18 AM
evokid511's Avatar
if you do it right there is no harm to anytihng on your car
Old Feb 14, 2009 | 11:45 AM
-Evo Aaron-'s Avatar
If you do it correctly the majority of the damage is straight to the clutch, it will eat your clutch for sure because your slipping it, and if you do it wrong it will eat your t-case and so on, (I'm reffering to launching)
Old Feb 14, 2009 | 12:10 PM
chaotichoax's Avatar
search...there are 800 threads on this
closed...
