Uh oh!!! Help please
Old Feb 15, 2009 | 07:14 PM
  #31
stiftwevo's Avatar
yea i don;t think you can really remove it... i think ur going to need new onces.. that kind of stinks
Old Feb 15, 2009 | 10:12 PM
  #32
Adubb84's Avatar
That is unfortunate.. Tru using Meguires Plastx on it. If that does not work it is time for some new plastic covers my friend
Old Feb 15, 2009 | 10:17 PM
  #33
FastLearner's Avatar
You can try plastic polish, but I will bet you the damage is permanent. The acetone in the remover will dissolve plastic. Just ask your GF, that's how they remove acrylic nails by soaking them in acetone. Look at it this way, good excuse for a CF gauge overlay when you replace the plastic
Old Feb 17, 2009 | 11:55 AM
  #34
z06fun's Avatar
+1 for the plastic polish. This is stuff typically used on plastic rear windows for convertibles and such, one brand I have used is Plexus but it may not be aggressive enough for hard plastic like you are trying to polish. Marine stores have it, some auto parts stores carry it too. I know 3M makes something called "plastic polish" that works really well for things like this.
Old Feb 17, 2009 | 02:00 PM
  #35
Evokid8's Avatar
thanks guys, i fixed it
Old Feb 17, 2009 | 03:29 PM
  #36
EvoDom's Avatar
can you please share with my why you used acetone to clean your gauges, even so fro overspray, any nail polish remover will ruin a clear peice of plastic.
i like the cavileir idea
Old Feb 17, 2009 | 05:17 PM
  #37
EvoJoeIX's Avatar
i dont think he actually fixed it, he probably just took the lens off...
Old Feb 17, 2009 | 06:49 PM
  #38
Fawkz's Avatar
could get some plastic at home depot or somethin and cut it to fit your gauge (ie. replace it)
Old Feb 17, 2009 | 07:27 PM
  #39
Evokid8's Avatar
exactly what i did, come on guys im only 17 and i haven't messed around with chemicals on cars very much
Old Feb 17, 2009 | 09:24 PM
  #40
CJ2X's Avatar
So how did you fix it?
Old Feb 18, 2009 | 07:28 AM
  #41
ScoobySAM's Avatar
^he took out the lens...haha
Old Feb 19, 2009 | 06:54 AM
  #42
slvrr's Avatar
You can fix this but it will be difficult for sure. You need a quality polishing compound like Menzerna and a buffer. preferably a wool pad followed by a less aggressive polishing compound and a white or blue foam pad. This will work however it will be very difficult to manuver the buffer. Best of luck. The only other thing you might try first would be a headlight polishing compound and attach a modified pad to a dremel. Then get after it!!
Old Feb 19, 2009 | 07:18 AM
  #43
evotuner's Avatar
Originally Posted by RoadSpike
only way to fix it is to polish the plastic you chemically etched the plastic with acetone
Exactly what I was thinking. Sorry man.
Old Feb 19, 2009 | 05:09 PM
  #44
Sansone's Avatar
Originally Posted by Evokid8
exactly what i did, come on guys im only 17 and.......... my parents have too much money..... i haven't messed around with chemicals on cars very much
Fixed
Old Feb 19, 2009 | 05:11 PM
  #45
Julian's Avatar
Why on earth would you do that in the first place?
