ProSport Premium Gauges?
Old Feb 25, 2009 | 05:45 PM
20EvoDude05's Avatar
Well guys, I ordered a ProSport Premium Gauges, I got the Blue/White for the following: Boost/Oil Pressure/EGT.
I REALLY hope they are good stuff. They look amazing, that's a given. Any thoughts on these or any tips?
Old Feb 25, 2009 | 05:55 PM
shroomster84's Avatar
I've Had the Boost Volt Meter and Oil Pressure in my EVO for about 6 months now and I have yet to have a problem. I love the way they look! Just make sure to either have someone who knows how to install them cause the instructions are little less than impressive. Also you will prob need a reducer for your oil pressure gauge, i needed one for my oil temp and it didnt come with it. Other than that I don't a have a thing to complain about!
Old Feb 25, 2009 | 07:13 PM
boosted2x2's Avatar
i have the oil pressure/water temp./fuel pressure/and electric peak hold boost gauge. they are great and i have had no problem with them. they have been installed for 7 months now. all for under $275.
Old Feb 25, 2009 | 07:19 PM
Boltz.'s Avatar
FCOTM Winner
I've had pretty bad luck with them.
Gone through multiple EGT sensors. Went through one in a 20 minute lapping session.
Constant erradic readings from my boost gauge.
The buttons for the peak/warning/rest also rattles pretty bad.
They were cheap and look nice, but I wouldn't buy them again.
Old Feb 26, 2009 | 09:06 AM
EvoDom's Avatar
i have them.....work pretty well. im on my second mechanical boost gauge thou. so i would prolly go with the electrical boost gauge.
Old Feb 26, 2009 | 10:09 AM
D_Eclipse9916's Avatar
hmm wonder if my oil pressure gauge will give out...we will see...
Old Feb 26, 2009 | 03:48 PM
Man, seems like it's a hit or miss with these gauges. Well, I just ordered their 80mm Tachometer Gauge with built in shift light. I hope it's good stuff too. Anyone have these?
Old Feb 26, 2009 | 03:50 PM
Kracka's Avatar
I have Defi gauges in my car but a lot of my friends have the Prosports; if I were to build another Evo it would get Prosports since they look nice and are priced really low.
Old Feb 26, 2009 | 03:51 PM
AF-Evo8's Avatar
I've had the premium amber/white boost, oil pressure, and oil temp for over a year now with Zero issues, and they match the stock gauges perfectly.
Old Feb 26, 2009 | 03:57 PM
Kracka's Avatar
Also to add, my fiancee will be getting a set of the green/white gauges for her WRX.
Old Feb 26, 2009 | 04:20 PM
o-townFLA's Avatar
check this thread out... Official Prosport Gauge Thread
their's over 400 post for you to look over...
Old Feb 26, 2009 | 04:31 PM
That's sweet it matches the OEM cluster perfectly. I got the Blue/White tho, it should look awesome regardless.
Old Feb 26, 2009 | 08:16 PM
Epix_'s Avatar
The prosport gauges look amazing, but the stepper motors inside them are loud. There's a bunch of vids on youtube to check out as well.
Old Feb 26, 2009 | 09:04 PM
Unregisterd's Avatar
Originally Posted by c_sautter
Oh yeah, and the premium electric boost gauge has this annoying ring when you first start it up, everytime. I don't know how to get rid of it though.
As long as you have it hooked up to a constant, just push and hold the button on startup.
I've had the boost gauge for almost two years. The only issues I've had were my own fault. My sensor got wet and shorted out last summer, so I had to get a new one. And in the process of relocating the gauge, I screwed up the housing so the button cover fell off (I kinda like it better this way) and the stepper motor became a bit noisy on startup. I installed an oil pressure gauge a couple months ago, but I haven't hooked up the sensor yet. I'm definitely happy with them thus far.
Old Feb 26, 2009 | 09:18 PM
I have a hearing loss, so noise is not really concern unless it's pretty loud.
