ACT Clutch kit installed!
Old Sep 23, 2003 | 09:34 PM
evo1's Avatar
Cool ACT Clutch kit installed!
I'm close to 400 miles on my new ACT clutch kit and steel braided line, so I figured I'd post a short review of how it's working out so far.
My main objective was to have a very 'streetable' or 'as close to stock as possible' clutch.... BUT with more clamping power over stock. My evo is an everyday driver so I did not want something that was going to be a pain to drive on the street. However, with 300 at wheel now.... I could not afford to take my chances with a another fully stock set-up (voided tranny warranty or not)! The ACT kit seemed like the perfect choice since it's an upgraded pressure plate (approx 40% more clamping power over stock according to Dirk@ACT), yet it's designed to work with the stock disc. For the record, my stock clutch died at 9800 miles. The ACT kit includes an ACT pressure plate, throwout bearing and a stock disc. I decided to stay with the stock flywheel, opposed to going w/ a lighter Fidenza.... simply because I wanted a more 'streetable' set-up. Lastly, I had the flywheel resurfaced.... and opted to go with a new set of flywheel bolts.
You want a 'close to stock' clutch feel with slightly more pedal resistance? That is about the best way to describe the ACT pressure plate paired with the disc & flywheel. I can definitely feel the difference vs. stock, but it's very streetable, and it grabs very nicely. It took me about a day to get the feel for it due to the added pedal pressure.... but now it feels perfect! It seems to engage very similar to stock.... although possibly slightly quicker. I have not tried a true launch yet because of only 400 miles on it, but I'm assuming it's very similar to stock by the way it feels. I did slip it once so far.... and no smell at all whatsoever.
So far... I'm VERY satisfied with this set-up! It's definitely feels allot stronger than the stock set-up.... and at $500 it's good bargain IMHO. I fully recommend it thus far.... and I'll post again once I get more miles on it.
Old Sep 23, 2003 | 09:58 PM
BushBurninEvo's Avatar
how was the install?
Old Sep 24, 2003 | 06:13 AM
sir lurks alot's Avatar
Old Sep 24, 2003 | 06:18 AM
evo1's Avatar
I did not install it myself... I have a local performance shop that I trust to do a long job like this -- no way would I have the tools, space (I have a 1-car garage), or time. However, they said that it wasn't bad but it takes time. They charged me a flat $650 but they do great work... I trust them over the dealer by far! The owner races RX-7's. I'm sure that David Bushur knows him because they've competed against each other many times... the name is Lowe's Performance.
You have to assume that it's the same as installing a stock clutch set-up... the ONLY difference is that that ACT pressure plate is more beefy.
Old Sep 24, 2003 | 06:42 AM
sr20det91's Avatar
Good to know. I'm starting to think about aftermarket clutches myself.
Have you experienced any "chatter" or increased decel noise from the throwout bearing?
Old Sep 24, 2003 | 06:47 AM
chinalfr's Avatar
Cool. I like ACT clutch too. It will be my next clutch after the stock wear out.
Great setup, evo1.
Old Sep 24, 2003 | 07:24 AM
batty's Avatar
i got one in my eclipse ACT clutch 2100 . I LOVE it. I would definatley go with them
Old Sep 24, 2003 | 07:26 AM
RTW EVO's Avatar
I had the ACT on my s2000 and I loved it, when mine goes (probably over the winter) it will certainly be my choice
Old Sep 24, 2003 | 07:32 AM
turbofreek's Avatar
i have the 2600 on my eclipse, its the best clutch out there. i know, because i had 3 clutchmasters stage3's none lasted over 6 mo. and my act is going on 2 years of 5-6 6k clutch dumps a week
Old Sep 24, 2003 | 07:43 AM
evo1's Avatar
No "chatter" or increased decel noise whatsoever! It feels very close to the stock set-up, with the exception of increased pedal resistance due to the upgraded pressure plate, and I think it engages 'slightly' quicker than stock (seems to engage at approx. 75% to the floor). I really dig this new set-up because the stock pressure plate felt weak to me....
The increased clutch pedal pressure takes a day or two to get used to, but then becomes obvious that it's a nice improvement. I feel like I have more control with the upgraded pressure plate, my shifts are smoother, and the clutch seems to grab very nicely... no grinding!
Old Sep 24, 2003 | 07:46 AM
evo1's Avatar
Holy shizzznit!!!
That's good to know man... thanks! Hey... I couldn't bring myself to drop over a grand on an Exedy, and I wanted a clutch that is very streetable, quiet, and easy to launch. This was a 'no brainer' for me at only $495.
Old Sep 24, 2003 | 07:49 AM
evo1's Avatar
Great setup, evo1.
Thanks mon...
Old Sep 24, 2003 | 08:09 AM
YEVOVIII's Avatar
WHERE???
Did you get the clutch. I can't find anything on the net.
Thanks
Old Sep 24, 2003 | 08:11 AM
Thoe99's Avatar
Hey what's up Evo1! Did you ever remove your restrictor at the time you got your SS line in? I got my SS line done only.
Old Sep 24, 2003 | 09:49 AM
N10S's Avatar
Re: ACT Clutch kit installed!
Nice write-up!!
It sounds like a great solution, with no detriment to drivability. MMC is probably a shareholder in ACT
Its also nice to hear from others that have used Act products successfully with no issues after hard usage. This will be an excellent choice for many !
Thanks again evo1 !
N10S
