Check engine light after test pipe install?
Old Apr 18, 2009 | 06:27 PM
krisdlm's Avatar
Post Check engine light after test pipe install?
I keep gettting a check engine light even after I put the spacer for the test pipe on. Any idea how to solve this problem b/c I don't want to keep clearing the code if it just comes back?
Old Apr 18, 2009 | 06:31 PM
cfdfireman1's Avatar
search
Old Apr 18, 2009 | 06:36 PM
silver evo8's Avatar
spark plug non fouler for an easy fix
Old Apr 18, 2009 | 06:39 PM
shifthard's Avatar
yea just get a defouler for the o2 on the catback exhaust if u have one if not then ur gonna have to install a o2 bung and install a defouler for the o2.
Old Apr 18, 2009 | 06:40 PM
Domolution's Avatar
werd!!!
Old Apr 18, 2009 | 06:41 PM
max4rw's Avatar
spacer? do u mean the spark plug non-fouler if thats what u mean then it should have worked, u need to unplug the battery for 5-min so the code will clear!
Old Apr 18, 2009 | 06:42 PM
Evo1001's Avatar
I used the spark plug non fouler (stacked 2 of the longer ones), and relocated it in the catback bung for more room. no CEL for me. I put my AFR sensor in the test pipe.
Old Apr 18, 2009 | 06:52 PM
C130flyer's Avatar
welcome to the "CEL test pipe club"
member since last month......
Old Apr 18, 2009 | 06:54 PM
garcia10's Avatar
go to ams' online store and they have a cel fix you can buy....or go to speedelement.com...they all are pretty much the same....i bought mine from speed element....no cel on mine from my test pipe...there is also a way to delete the code for the rear o2 sensor....bunch of the evo owners in my area that are tech savy do it that way....either way works fine..pm me if you want details
Old Apr 19, 2009 | 09:06 AM
JakeTheVIII's Avatar
https://www.evolutionm.net/forums/ev...ouler-how.html
Old Apr 19, 2009 | 09:19 AM
Smike's Avatar
That ^
Closed.
Barrett006@aol.
14
Feb 7, 2011 06:59 AM
stlgrym3
Apr 16, 2010 07:32 AM
cfralliart
Mar 13, 2009 08:31 PM
03silverevo8
Feb 18, 2005 04:19 PM
TaiwanEvo
Jul 25, 2003 02:52 PM
