bad gas mileage
Old May 25, 2009 | 11:02 PM
  #31
big block ix's Avatar
I'n the stroker I always get into 5th gear by 40mph helps my mpg...
Old May 25, 2009 | 11:06 PM
  #32
silviaz145's Avatar
use the fuel system cleaner,it works!
Old May 25, 2009 | 11:11 PM
  #33
BluEVOIX's Avatar
Originally Posted by musca999
Who buys an evo and worries abt gas mileage anyway?
Hense why we bought a 4 cylinder turbo performance car instead of a v8 supercharged.
Besides doesnt the Z06 get around 27-32 mpg? If a V8 7.2 L motor car can get high 20's mpg why cant we want or expect a 2.0 four cylinder to do it as well.
To get back on topic this car generally performs 19-22 mpg in the summer and 16-18 mpg in winter (give or take 1 mpg and all/mostly city driving). Highway driving in summer time maybe ~24 mpg and winter ~21mpg.
I'm not sure what could be wrong with your car but your not too low to panic about. But I generally dont like the idea of cars being stored because I feel that they just rust away. Check the plugs if they need to be replaced and also see if the maf needs to be cleaned.
One thing you can do that will increase mpg's far better than breathing mods (intake exhaust) is taking rotating mass off the engine. Turbo cars work different than NA. Naturally aspirated respond well in the MPG department with exhaust and intake mods but turbo cars have the turbo that gets in the way of exhaling.
Although its NA but back in 2003 I had an 03 nissan sentra ser spec v. I got header, exhaust, intake for the car but nothing changed the mpg's as much as pulling the balance shaft out. Our evo's balance shaft is a rod that spins but that thing had a separate gear box in the oil pan creating resistance on the motor. When I removed this thing I went from my usual 180-190 miles per 10 gallons of filling up to 240-260 miles per filling up 10 gallons. So I basically increased ~7 mpg's.
After that car I got an SRT-4. I did the same thing exhaust, intake then got a bigger turbo but it had no big change. I went from 21 mpg's to 24 mpg's. But that was mostly from a bigger turbo and not much increase from exhaust or intake.
So that is why I am concluding best way to increase mpg's is removing rotating mass or resistance from the motor. Unless you can tune for normal driving (closed loop operations).
For now as I mentioned earlier, check the following:
-spark plugs
-clean maf if needed
-boost leaks
-accelerate with the least amount of throttle (most vacuum)
-also I didnt see if you already did an oil change after the storage?
Old May 26, 2009 | 03:10 AM
  #34
CJ2X's Avatar
Originally Posted by riceball777
sounds like normal gas millage to me
for the 60k miles i had my evo my lifetime average gas millage is 17mpg. If i run it hard i can get 15mpg and if i never see boost i might get 19mpg. The evo is a sub 200mpg car and all the evo owners i know also get about 15-18mpg on average
+1
Old May 26, 2009 | 03:37 AM
  #35
lilevil's Avatar
the two things I do to get better MPG is shift at lower RPMs and of course stay out of boost. That usually makes a noticeable difference.
not trying to hijack the thread but...
How do you clean the MAF?
Do those fuel system cleaners really work? I kinda read about those products on another thread but no straight answer.
Old May 26, 2009 | 03:58 AM
  #36
BEISSEN's Avatar
After my tune I went from 180 Miles Per Tank to roughly 240 if I drain the tank almost.
Old May 26, 2009 | 07:05 AM
  #37
SmurfZilla's Avatar
This is all I saw....I'm using this quote to convince my wife I need a bigger turbo. LOL.
Old May 26, 2009 | 09:21 AM
  #38
apevo8's Avatar
ya i should clean the maf and i did an oil change when i first started the car up for summer
Old Dec 12, 2012 | 07:02 PM
  #39
fastyouth1313's Avatar
Back to life!?!?!
Did you ever figure out what it was?
I'm getting horrible gas mileage
Any help would be great
Old Dec 15, 2012 | 01:08 AM
  #40
jeremy52048's Avatar
it still amazes me how our cars will get so much worst mpg than new cars like the camaro SS/mustang GT, and get fewer power.. lol.. oh well
Old Dec 15, 2012 | 01:13 PM
  #41
Wrathafier's Avatar
on my evo 9 i have been getting around 20 but seen as low as 16 driving locally.
EVOizmm
Feb 14, 2025 05:39 AM
bloody_angel1
Lancer Troubleshooting
76
Jun 28, 2018 05:22 AM
taylorgang
Apr 2, 2012 08:51 PM
supersnow
Dec 5, 2007 04:20 PM
dewman1999
Lancer Engine Tech
14
Mar 10, 2005 05:45 PM
