Anyone know how to adjust JDM Hids
Old May 23, 2009 | 09:40 AM
Cloudx71's Avatar
Hey,
I just got some JDM hids. I was looking through some threads and found the standard bolt to adjust it. Unfortunately the bolt only lowers the headlight and does not raise it. Does anyone know any other way to raise the headlight beam? I also have a GSR so no in cabin adjust. IF anyone knows anything please let me know!
-Tyler
Old May 23, 2009 | 09:53 AM
randomevo's Avatar
only 2 screws for high beams. if it lowers the light turn it the other way. or tighten the other screw.
check this thread for pics
https://www.evolutionm.net/forums/ev...ml#post6851604
Old May 23, 2009 | 11:14 AM
Cloudx71's Avatar
I tightened the screw but it only goes up to a certain point. If anyone has any pictures, that would be great, that thread does not specify which screw to turn.
Old May 23, 2009 | 11:17 AM
Cloudx71's Avatar
Oh I also meant the low beam HID not the highbeam.
Old May 23, 2009 | 12:03 PM
randomevo's Avatar
check the the, the answer is in there.
there are only a couple of mounting screws
without the adjusters i don't know how else you would, unless you turn the screw where the adjuster should be.
Old May 23, 2009 | 12:13 PM
GPTourer's Avatar
Maybe you have it as high as it goes? I seem to remember a few people complaining early on about how low they felt the low beams were.
