I need boost gauge help
Old Oct 3, 2003 | 05:09 PM
Sano's Avatar
I am looking for a boost gauge that reads in psi and not bars. I would also like some part #'s or vendors that carry the product I am looking for. I have ran searchs and all I can find is gauges that read in bars.
I am also in eed of somthing to mount it with. I don't like the location of the rmr, and the buschar looks a lil plain. is there any other mounts or pods available
thanks
Old Oct 3, 2003 | 05:13 PM
ChrisS.'s Avatar
Have you tried http://store.summitracing.com/defaul...d=10&x=11&y=12 They have a TON of gauge's.......good luck
Old Oct 3, 2003 | 07:46 PM
blackmantis's Avatar
www.roadraceengineering.com
the boys there will be able to help
Old Oct 3, 2003 | 07:47 PM
mikec's Avatar
Pretty hard to beat the Autometer Z-series mechanical gauges, especially when you consider cost.
http://www.buschurracing.com/cgi-bin....cgi?19X376545
http://www.evolutionsports.com/products.cfm?catID=110
http://www.evolutionsports.com/products.cfm?catID=109
Old Oct 3, 2003 | 08:12 PM
Sano's Avatar
Is there a gauge pod kit available yet. That is what I would really like. A double or triple set up.
Old Oct 4, 2003 | 12:51 PM
Sano's Avatar
anyone on the site have a setup they would recomend. Thats with a boost gauge that reads in psi
Old Oct 4, 2003 | 01:16 PM
sr20det91's Avatar
I have an Apexi, that reads in PSI. I got from a local shop for about $116. Its backlit blue, which I think looks great and its easy to read. Go to their site and you will see it.
BTW.. I got the 60mm one and its dead on accurate, I had it tested by my PMEL shop at Andrews AFB.
Old Oct 4, 2003 | 05:55 PM
Liandrin11's Avatar
You should check out EDO Performance as well. They carry all the Defi gauges if you want some quality; bar or psi.
Old Oct 7, 2003 | 05:46 PM
Sano's Avatar
I need to order a bracket or pod TONIGHT!!! I do not want the rmr its to big and in the way, is the buschar the only option.
Old Oct 7, 2003 | 05:53 PM
eevoo's Avatar
I have the exact same setup as pictured on the burschur website, autometer sport comp from ebay ($49.50 incl. shipping) and the burschur gauge pod. I T'ed it to the BOV vacuum/boost line, and I have to say it works great. It's dead-on accurate. If you want to do 3 gauges I would relocate the radio (do a search on here) and get a black panel to mount 3 gauges across in the stock head unit location. I see that in my future when I have more $$.
Good luck!
Old Oct 8, 2003 | 07:33 AM
Technoz's Avatar
PM Fireball, he makes an a pillar replacement that holds 3 52mm gauges. It's awesome, I've got it on my evo.
more pictures here
They are Autotechnic AC S7 gauges btw.
Jason
