Need help with driveability issue
Old Jul 3, 2009 | 04:43 PM
Hioffcr's Avatar
From: Killeen, Tx via Fayetteville, NC via Worthington, OH
When cruising at any speed the car seems to slow down go back to speed slow etc. During this time MPH and RPM stay the same, as well as boost level (vac). Every once in a while it will throw a P1033 and p1034 code.
Old Jul 3, 2009 | 06:04 PM
Hioffcr's Avatar
Anyone?
Old Jul 3, 2009 | 06:09 PM
def1's Avatar
your oxygen sensor doesnt work is what the codes are saying.
Old Jul 4, 2009 | 06:11 AM
Hioffcr's Avatar
Are our cars that sensitive to the o2 sensor that it would cause driveability issues?
To better clarify the issue.....when cruising it feels as if I start to hydroplane.
Thanks.
Old Jul 4, 2009 | 07:24 AM
houckeah's Avatar
I'm just taking a shot in the dark because not a lot of people have posted yet. It sounds like a very annoying issue, I'm obviously no mechanic...
Possibly a clutch issue? Either worn clutch or failing pressure plate. I would assume if this were the case that when the car slowed down the rpms would spike up. So this is likely wrong.
Definitely replace your o2 sensor. Our cars are sensitive, that likely isn't the problem though... I'm saying replace it so it doesn't cause further problems and you want to fix any problems you know about.
It could be any number of things. Have you noticed it only happens under certain conditions? Do you lose power when it happens or can you accelerate through it?
Small list of possibilities: Fuel pump, fuel relay, injectors, fuel filter, air intake, maf... any number of sensors...
Old Jul 4, 2009 | 01:41 PM
barneyb's Avatar
My car does this for about the first mile of driving then it is okay. No codes but then I have all the codes shut off, he hee. The car speeds up and slows down so I put the cruise control on (I have cruise installed) and let it and the engine fight it out.
I'd guess that what is happening with my car is the ECU is trying to go into feed back mode from the oxygen sensor but the slow responding sensor causes it to drop out. Then it tries again. After a bit of driving it is fine. If your car does this on the highway you probably need a new sensor.
Old Jul 4, 2009 | 07:52 PM
Hioffcr's Avatar
Thanks for the input. I tried to replace the sensor, but that SOB is tough to get to. May hae to suck it up and take it to the shop.
Old Jul 6, 2009 | 03:44 AM
tortyklubevo's Avatar
hope this helps
DTC P0090: Fuel Pressure Solenoid Circuit
DTC P0101: Volume Airflow Circuit Range/Performance Problem
DTC P0102: Volume Airflow Circuit Low Input
DTC P0106: Barometric Pressure Circuit Range/Performance Pro
DTC P0107: Barometric Pressure Circuit Low Input
DTC P0108: Barometric Pressure Circuit High Input
DTC P0111: Intake Air Temperature Circuit Range/Performance
DTC P0112: Intake Air Temperature Circuit Low Input
DTC P0113: Intake Air Temperature Circuit High Input
DTC P0116: Engine Coolant Temperature Circuit Range/Performa
DTC P0117: Engine Coolant Temperature Circuit Low Input
DTC P0118: Engine Coolant Temperature Circuit High Input
DTC P0121: Throttle Position Circuit Range/Performance Probl
DTC P0122: Throttle Position Circuit Low Input
DTC P0123: Throttle Position Circuit High Input
DTC P0125: Insufficient Coolant Temperature for Closed Loop
DTC P0128: Coolant Thermostat (Coolant Temperature Below The
DTC P0130: Heated Oxygen Sensor Circuit [SEMSOR 1]
DTC P0131: Heated Oxygen Sensor Circuit Low Voltage [SEMSOR
DTC P0132: Heated Oxygen Sensor Circuit High Voltage [SEMSOR
DTC P0133: Heated Oxygen Sensor Circuit Slow Response [SEMSO
DTC P0134: Heated Oxygen Sensor No Activity Detected [SEMSOR
DTC P0135: Heated Oxygen Sensor Heater Circuit [SEMSOR 1]
DTC P0136: Heated Oxygen Sensor Circuit [SEMSOR 2]
DTC P0137: Heated Oxygen Sensor Circuit Low Voltage [SEMSOR
DTC P0138: Heated Oxygen Sensor Circuit High Voltage [SEMSOR
DTC P0139: Heated Oxygen Sensor Circuit Slow Response [SEMSO
DTC P0141: Heated Oxygen Sensor Heater Circuit [SEMSOR 2]
DTC P0171: System too Lean
DTC P0172: System too Rich
DTC P0181: Fuel Tank Temperature Sensor Circuit Range/Perfor
DTC P0182: Fuel Tank Temperature Sensor Circuit Low Input
DTC P0183: Fuel Tank Temperature Sensor Circuit High Input
DTC P0201: Injector Circuit-Cylinder 1, DTC P0202: Injector
DTC P0234: Turbocharger Wastegate System Malfunction
DTC P0243: Turbocharger Wastegate Solenoid Circuit
DTC P0300: Random/Multiple Cylinder Misfire Detected
DTC P0301: Cylinder 1 Misfire Detected, DTC P0302: Cylinder
DTC P0325: Knock Sensor Circuit
DTC P0335: Crankshaft Position Sensor Circuit
DTC P0340: Camshaft Position Sensor Circuit
DTC P0401: EGR Flow Insufficient Detected
DTC P0403: EGR Control Circuit
DTC P0420: Catalyst Efficiency Below Threshold
DTC P0441: Evaporative Emission Control System Incorrect Pur
DTC P0442: Evaporative Emission System Leak Detected (Small
DTC P0443: Evaporative Emission Control System Purge Control
DTC P0446: Evaporative Emission Control System Vent Control
DTC P0451: Evaporative Emission System Pressure Sensor Range
DTC P0452: Evaporative Emission System Pressure Sensor Low I
DTC P0453: Evaporative Emission System Pressure Sensor High
DTC P0455: Evaporative Emission System Leak Detected (Gross
DTC P0456: Evaporative Emission System Leak Detected (Very S
DTC P0461: Fuel Level Sensor Circuit Range/Performance [SUB]
DTC P0500: Vehicle Speed Sensor Malfunction
DTC P0506: Idle Control System RPM Lower Than Expected
DTC P0507: Idle Control System RPM Higher Than Expected
DTC P0513: Immobilizer Malfunction
DTC P0551: Power Steering Pressure Switch Circuit Range/Perf
DTC P0554: Power Steering Pressure Switch Circuit Intermitte
DTC P0622: Generator FR Terminal Circuit Malfunction
DTC P0830: Clutch Pedal Position Switch Circuit Range/Perfor
DTC P1400: Manifold Differential Pressure Sensor Circuit Mal
DTC P1603: Battery Backup Circuit Malfunction
DTC P2066: Fuel Level Sensor Circuit Range/Performance
DTC P2263: Intake Charge System Malfunction
Old Jul 6, 2009 | 10:11 AM
Hioffcr's Avatar
Thanks man. I have pretty much relegated myself to the fact the o2 sensor needs to be replaced. Gonna try to get it taken care of today and see if it makes any difference
Originally Posted by tortyklubevo
hope this helps
Old Jul 7, 2009 | 04:09 PM
Hioffcr's Avatar
Okay....O2 sensor has been replaced. Issue still lingers, and is driving me nuts. I am not loosing power when it happens and I can actually throttle thru it.
Any more ideas?
Old Jul 7, 2009 | 06:04 PM
cfdfireman1's Avatar
so...
Thanks.
..you lose steering in the front end?
Old Jul 7, 2009 | 08:17 PM
Hioffcr's Avatar
no, it is that instant feeling of resistance on the driveline.
Fredj
Lancer Troubleshooting
33
Aug 17, 2018 10:36 AM
CT9A PR
Oct 29, 2015 06:44 PM
0to140in9
10
Sep 21, 2015 06:30 AM
02BLUR
Nov 23, 2010 06:42 AM
BadazzCR
Aug 23, 2008 07:40 AM
