Where is the crank sensor located?
Old Jul 4, 2009 | 03:37 PM
MTRJunior's Avatar
Hey guys,
I have a quick question, and couldn't find it through the search function. Where is the crank shaft position sensor located on the evo ix?
Thanks!
Old Jul 4, 2009 | 04:22 PM
MTRJunior's Avatar
it's under the timing cover, by the crankshaft!
ohhh ok thanks!
Old Jul 4, 2009 | 09:26 PM
EvoJoeIX's Avatar
its right by the bolt you use to turn the motor over...
follow your timing belt to the bottom of the motor and pull off the pulley and shes hiding in there
here you go
