Beatrush fitment question with AMS FMIC and Piping
Hi,
First, I recently had AMS upper and lower I/C piping and an AMS FMIC installed at Dentsport Garage here in MA. Made a tremendous difference in my car. On their Dyno Dynamics dyno, I gained 30 WHP peak, but even more importantly ~75 on the top-end with these parts and a cone intake (from a drop-in panel K&N)!
Anyway, my stock underpanel was not in good shape, and I'm currently running no underpanel, but I would like to get the Beatrush (considered the Carbing as well).
After many searches, I've found a few posts that the Beatrush fits with the AMS FMIC and piping. The posts said with no modification, but I just wanted to clarify if /how the front bracket fits on the AMS FMIC per these instructions, or if with no modification meant that the front bracket was not used. Is it strong "enough" with the other mounting points?
TIA!
EvoM how-to:
https://www.evolutionm.net/forums/ev...on-vii-ix.html
Another how-to:
http://evolvedperformance.com/?p=97
TIA!
EvoM how-to:
Another how-to:
Wondering the same... If I remember correctly, you can't use the stock center bracket and need to "fab" up your own to prevent sag in the middle, but I can't put my hands on that post right now.
I'd like confirmation on this too.
Hi,
TIA!
EvoM how-to:
Another how-to:
TIA!
EvoM how-to:
Another how-to:
just wondering.......did you get the beatrush underpanel installed and if so how do the install go? any mods need to be done?
thanks
Mine fit with no problems. The instructions I got were in Japanese, but there are some blurry pictures as well. Its time consuming if you stick with the hex head bolts. I went with dzus fasteners personally. A little work early, means you can take the whole thing off in a minute.
Faust
76
Nov 6, 2018 06:47 PM
peter*g
29
Nov 21, 2007 08:44 AM
