Running two fuel lines from the Double Pump
Old Jul 6, 2009 | 03:00 PM
rodent's Avatar
Running two fuel lines from the Double Pumper
Has anyone used the vent line and the stock fuel line together to deliver fuel? I was thinking about buying the Bushur since I'm not using the vent line right now.
Buschur Racing Dual Fuel Feed Line Kit
With continuing to push the limits of the Evolution sooner or later we knew more fuel would be required. A single Walbro just wasnt going to cut it. There was no solution other than a big bulky fuel cell so people started to do that. A very annoying mod in a street car.
With not wanting to do that a solution needed to be made. Buschur Racing came up with that solution. The Buschur Racing Double intank fuel system was born.
Over time and with more power another call for more fuel came in. After pondering upon a solution David Buschur came up with what you see here.... the twin fuel feed line kit.
After going to work on THE BAD BISH.... he finalized the fuel solution. After having some custom parts made, cutting the vent line and then simply running two seperate lines out of the double pumper, one to the factory feed line and one to the factory vent line. He then moved up front, under the hood and ended up with two fuel lines about one foot from the fuel rail.
What you will receive in the kit is:
* Gates Multi fuel line
* Stainless Steel Oetiker clamps
* Stainless Steel HP fuel clamps
* Stainless Steel 10 micron filter
* Custom Buschur Racing CNC Wye fitting
* Custom Buschur Racing CNC Fuel Rail Fitting
* Custom -6 swivel fitting
Thoughts???
Its either that or running a single -8an line from the Y close to the tank. Whats all the high HP guys doing to get fuel to the rail? I pretty sure the stock single line is my limitation right now. Currently running E85 with 1600cc, 30psi, 625awhp but would like more boost.
