Where could my short be?
So as of late I have some signs of an electrical short somewhere in my car.
None of these happen every time when I do them, probably 1 out of every 10 times, which is a lot.
When I turn on my right turn signal my radio goes off.
When I brake, my radio goes off.
When I accelerate quickly, my radio goes off.
Get a schematic, trace the wires back to a point where they all intersect. Start with the radio wiring, and work towards the other systems. Prob a bad ground. If all else fails, get another radio.
without putting too much thought into it I'd say it's your radio that has the short. My radio would radomly turn off in the prelude I use to have and I replace a corroded battery terminal and it fixed it. Electrical problems are really hard to diagnose exspecially when it's intermitent.
Before you do anything... rule this out first.
Check by the drivers side kick panel for those connectors. If they are corroded, go here.
https://www.evolutionm.net/forums/in...lins-rain.html
GL
GL
