Leaking Samco Radiator Hoses on my Evo VIII
Old Jul 14, 2009 | 11:06 AM
whitebeast2's Avatar
I installed Samco radiator hoses about a year ago with stock radiator clamps. They seem to be fatigue because there's a small leak on the water thermostat housing.
What kind of clamps do you recommend. Don't know if regular clamps will eventually damage the hoses.
Samco clamps are expensive and hard to find. Any suggestions?
Thanks for the help!
Old Jul 14, 2009 | 11:11 AM
cpoku's Avatar
You can try t-bolt clamps
Old Jul 14, 2009 | 11:17 AM
kimletrim's Avatar
Registered User
I have seen Samco hoses develop slight tears which then lead to leaks. The solution was to buy coolant hoses from NAPA which appeared to be stronger and more reliable than the thing Samco hoses.
Old Jul 14, 2009 | 12:07 PM
AWD_Terror's Avatar
i just use regular worm gear clamps on everything to be honest.
esp for coolant hoses, there is no need to bother with Tbolts. You are gonna waste more effort getting them on then you need to.
Old Jul 14, 2009 | 01:45 PM
Ev0ikon's Avatar
^yUP. Normal worm clamp is more than sufficient. Don't over tighten it or the hose will tear.
Old Jul 14, 2009 | 02:39 PM
TurboJuice's Avatar
Another in for normal worm clamp. Check to see if the hose is damaged?
Old Jul 14, 2009 | 04:41 PM
AznEvoIX's Avatar
Do it DSM Style.
1) Get some high-tensile duct tape (3M is the ****.)
2) Cut the HT Duct Tape to approx the width of the clamp plus a couple millimeters.
3) Wrap around the ends of the hose that will be held by the clamp.
The duct tape might be ghetto to some, but its a surefire fix for longevity.
Old Jul 15, 2009 | 07:12 AM
xi0V3MR's Avatar
worm clamps are eye sores sometimes. well, most of the time.
Old Jul 15, 2009 | 07:38 AM
AWD_Terror's Avatar
if you properly size them its not too bad.
Tbolt clamps are just as much of an eye sore IMO. Clamps in general look ugly.
Man. . . now that I think of it. . . maybe ill start anodizing some clamps and selling them. lol. I know no one would pay for them though. lol
Old Jul 18, 2009 | 08:16 PM
My hoses did not fit that tight. I just contact Samco to see if there's anything that can be done. I'll keep all updated.
Thore
Jun 7, 2015 10:53 AM
Eric Lyublinsky
Sep 14, 2013 12:26 PM
asu11
15
Jan 3, 2012 05:44 PM
MISHI
13
May 8, 2011 11:04 PM
xcuzme
Jun 27, 2007 07:01 PM
