WHat is the torque specs for intake manifold....I have a bad vacuum leak
SubscribeSo I've had a bad idle issue since i got my car started....thought it was the IAC.....its brand new so what are the chances thats its bad. Spoke to a mitsubishi tech and he said for how high my car was idling (2500-3000 rpms) it sounded like a bad vacuum leak....most likely from the intake manifold. The shop I took the car too left my IAC unplugged so its idling at 1500 (1000 with AC on) but I'm getting a code TPS...most likely because its (IAC) unplugged.
I'm buying another torque wrench tonight (assuming after I spray some PB Blaster were the intake manifold and head and it gets into the motor) what is the torque specs for the bolts holding it down to the head?
I searched and didn't find anything but I'm still searching (looking over the serice manual too).
All 12mm bolts/nuts need to be torque to 15 ft/lbs and all 14mm nuts/bolts need to be torque to 26 ft/lbs.
thanks....trying the pb blaster test first.
make sure you've got all the injector o-rings installed. I had a nasty leak that I believed to have come from the intake manifold and it turned out to be a bad oring.
Good luck!
Good luck!
Not to be mean, but you didn't look very hard. Here's the list for future reference. Bookmark it.
https://www.evolutionm.net/forums/ev...cs-thread.html
Thats cool thanks for letting me know.Originally Posted by AIEvo9MR
Not to be mean, but you didn't look very hard. Here's the list for future reference. Bookmark it.https://www.evolutionm.net/forums/ev...cs-thread.html
I tried the PB Blaster test and it yielded no results. I've got a lead for a Mitsu tech that works on EVO's for the dealership he works for....trying to get him to take a look, I'm tired of messing with this car.
Quote:
Is that what its spec'ed at? When I took them off they required a **** ton more force than that. Felt like 60+ ft/lbs. I had to attach a makeshift breaker bar on there to get them off on the bottom of the intake Originally Posted by S2kracka
