headlightt?
Low beam headlamp
HID-D2S
High beam headlamp
9005
Parking light
2825
There you go, might want to check first maybe it's not the bulbs but a different problem, kind of odd for all the bulbs to go at once.
HID-D2S
High beam headlamp
9005
Parking light
2825
BS, the same (what is NEARLY the same). Asian made HID bulbs are ALL CRAP. The quality standards between OEM quality and Asian made HID bulbs is no comparison. I work for a major USA HID ballast manufacturer and the Asian vs European made bulbs (Philips, Osram, GE) are very different. Asian made bulbs can and frequently do damage the ballast when they fail. Everything about them is cheap, the fill of metal halide salts, the non thoriated tungsten electrodes, the quartz glass, the base support, on and on it goes. For only a little more money you can get new OEM quality bulbs.
Cheers!
but im on the autozone website and here are the opitions what ones would it be???????????
Back Up Light Switch
Bulb - Back Up
Bulb - Cornering Light
Bulb - Dome Light
Bulb - High Mount Stop Light
Bulb - License Plate Light
Bulb - Parking Light
Bulb - Back Up
Bulb - Dome Light
