Evo 8 stuggling at wot, and poping
Old Jul 23, 2009 | 08:41 PM
ChEvo8's Avatar
thanks i will
Old Jul 23, 2009 | 08:42 PM
evokid511's Avatar
gl let us no
Old Jul 23, 2009 | 08:43 PM
ChEvo8's Avatar
wow this is my first post looking for help and man i gots to say thanks evom community you guys are really helpful.
Old Jul 23, 2009 | 08:48 PM
evokid511's Avatar
thats what everyones here for haha
Old Jul 23, 2009 | 09:02 PM
ChEvo8's Avatar
thanks
Old Jul 23, 2009 | 09:41 PM
Srt4...'s Avatar
delco is the problem...!
Old Jul 23, 2009 | 10:22 PM
FQ-300's Avatar
NGK BPR7ES is what you need, gapped at .026. You do not need to move one step colder (NGK BPR8ES) with the modifications you have.
Old Jul 24, 2009 | 02:47 AM
knightrider4g63's Avatar
Go to ebay for the ngk's you'll find them cheap
Old Jul 24, 2009 | 02:53 AM
TS8's Avatar
TS8
Check your COILS, that was my problem with the same symptom.
Old Jul 24, 2009 | 12:55 PM
ChEvo8's Avatar
it was definantly the gapping. I gapped the ones i had on and took it for a test and it worked and no popin or hesitation or nothing. did a few pases. worked really well and it almost kinda did it after about 5 pases so gaping was the main problem now to get rid of the problem 100% ima go get the NGK's thanks guys. you guys were alot of help.
Old Jul 25, 2009 | 06:13 PM
WRCevo9's Avatar
When you say "pops" do you mean that the intercooler piping comes undone? When I had only TBE and the Injen intercooler piping and intake, my car did the same thing. I would go to wide open throttle and BANG! It would take half an hour to drive 5 miles with the terrible trembling the car would do. The car would drive well until it wanted to create pressure at around 3k so you had to shift at 2k and drive home in 5th going 30mph at the most. What did the trick for me was to get a boost controller because when I hooked my computer up to the OBD-II port, the car was creating 40PSI!! Boost controller brought it back down to 21 PSI or even 15 PSI, and the car was fine.
Old Jul 29, 2009 | 05:29 PM
generalu's Avatar
Lesson learned.
Old Jul 29, 2009 | 06:08 PM
DIDYSIS's Avatar
get some good plugs and gap them right !!!!
Old Jul 29, 2009 | 06:14 PM
darkside4G63's Avatar
oreily's, auto zone, or advanced should have them or be able to get them in the afternoon or next day at the worst. they also can check with other stores for you. done it several times myself
Old Jul 29, 2009 | 06:15 PM
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
