Cannot access the ECU for Diagnostics - EVO9
Old Jul 27, 2009 | 09:13 AM
west_minist's Avatar
Hello:
A friend of mine just put together is evo 9. So he was getting a code and took it to a shop to run a diagnostic while he gets an alignment. The shop check the code and cleared it. This was a Friday.
Saturday, he took the car by his mechanic and checking for another code, he could not get access. He then came by me a few days later and I cannot even connect with Mut II/III tool or even Ecuflash.
We took it back to the shop that first test the code and nothing. There cannot even get anything.
Do anyone know what the problem can be?
Old Jul 27, 2009 | 09:53 AM
1d10t's Avatar
Either faulty scan tool, signal line/pin fitment, or bad ecu
Old Jul 27, 2009 | 09:56 AM
So faulty scanner. It could be that, although all looks well. Ecu working. Car driving.
Old Jul 29, 2009 | 04:49 PM
generalu's Avatar
If the first shop that was able to read the codes can't re-read, the culprit might be ecu pins. Check for that.
Old Jul 29, 2009 | 04:53 PM
wevo1985's Avatar
check your fuses. could be a blown one causing both the light and that you cant connect to the ecu.
Old Aug 22, 2009 | 03:50 AM
most wanted's Avatar
I had a similar problem with my evo 9, when I connect the launch to the car I wasn't getting nothing after doing some checks I realize my central locking fuse was blown after i changed that everything worked fine
Old Aug 22, 2009 | 09:18 AM
AznEvoIX's Avatar
Fuse!
sabastian458
43
Nov 2, 2015 01:35 PM
leo_99
Feb 25, 2013 08:20 AM
Evo_Matt
Feb 13, 2011 08:24 PM
Redmondgold
10
Jun 24, 2006 11:10 AM
