Problems with evo, need help
Old Aug 11, 2009 | 01:21 PM
Arkitek's Avatar
So last night while
driving my Evo my brake light came on while I was braking ... Then at the stop light my car did not want to go in first on the first try ... I didn't know if these things were related but my friend told me he thinks my master brake cylinder might be going out. Could these problems be related and is that the problem? I'm hoping so. The brake light only comes on when I brake hard but my brakes work fine and I have plenty of pad life. From checking last night and today it seems the first gear shifting problems only come on when the brake light is on but I could jar just gotten lucky... Thanks for any help or ideas.
Old Aug 11, 2009 | 01:32 PM
Chemwarrior's Avatar
Your dash brake light is an indication that either your brake pads are going out or your brake fluid is low. I don't think that your two problems are related though.
Old Aug 11, 2009 | 01:37 PM
chaotichoax's Avatar
Originally Posted by chemwarrior
your dash brake light is an indication that either your brake pads are going out or your brake fluid is low. I don't think that your two problems are related though.
+1
Old Aug 11, 2009 | 02:05 PM
Arkitek's Avatar
Hmm Thanks wel I checked them
and they all seemed good upon visual inspection ....
Old Aug 11, 2009 | 02:10 PM
meckert's Avatar
The clutch master and brake master share a common resevoir...so yes they are related. you may have a leak at the clutch slave or are just low on brake fluid.. add some and bleed what you have if problem persists.
Old Aug 12, 2009 | 02:56 AM
mini_evo's Avatar
Originally Posted by meckert
the clutch master and brake master share a common resevoir...so yes they are related. You may have a leak at the clutch slave or are just low on brake fluid.. Add some and bleed what you have if problem persists.
this.
Old Aug 12, 2009 | 05:15 AM
Dsm_Danny's Avatar
You're sure the fluids are okay? Because if the brakes are working fine and the light comes on it usually mean brake fluid is low like the other guy said.
Old Aug 12, 2009 | 11:02 AM
Arkitek's Avatar
ill be looking at all this today again guys. been working a lot. thanks for the help
